Regular readers of this forum may recall that I built two dual-opposed subs in 1.5L enclosures wrapped in large books. Both had scan-speak drivers, the 9" and 11" ones. The 11" (28wxxxx) drivers were very expensive. I built that sub in august 2024. It always had a weird chuffing sound from one of the drivers that I thought was air somehow leaking, like through the screw holes or at the flange, but I never could get the gremlin to go away. It was showing up in my REW measurements too, as a lot of distortion from that one sub at below 30hz.
So a couple weeks ago, with some time off, I built completely new, and actually quite a bit better boxes, this time using the 3/4" baltic birch for the tops and sides but 1" for each end. And I made super-sure, using gaskets, wood glue, and pocket screws, that the cabinet had no air leaks and no way for air to get around the offending driver.
Still the chuff-chuff. Very pronounced at 20hz, whereas the other 11" and the two 9" had zero chuff-chuff. Sigh. A shout-out to Madisound here. The driver was out of warranty, but they dealt with me very fairly on a replacement, and also gave me pointers on how to look at the bad driver to see if there's something repairable. Adam at Madisound has always been super-helpful to me with long orders (crossover parts, Linkwitz kits, the works).
The new 11" arrives in a few days. Since I know you care, I'll update the forum on whether I solved the chuff. Our hobby isn't free, so I'm not particular upset, but wow, those scan-speaks have gotten so expensive. Were I to do it over again, I'd probably just buy Daytons and call it a day. I think I was feeling flush a couple years ago. But maybe if Trump gives me $5,000, I won't feel quite so bad.
