Hi all - I recently built an active 3-way speaker system and am loving the overall sound, but I'm having some issues with the imaging and soundstage not being very solid. I've tried moving them to the typical equilateral triangle position with them toed in, flat against the wall, pulled way in sitting only a few feet away, higher/lower, etc. but nothing seems to help enough.
Woofers are 10" Aurum Cantus AC250-F1, midranges are Morel MDM 55 2" domes, tweeters are Aurum Cantus G2si ribbons. I have them crossed over at 24db/octave with a Linkwitz-Riley simulated filter. W-M 800Hz, M-T 3500Hz. One thing I noticed is that the midrange blends much better with less phase cancellation when it's inverted, even though 24db/oct should be a full 360 degree phase rotation. Either way, normal or inverted, the imaging isn't great. Vocals and center-mixed sounds don't sound like they're coming directly from a phantom center and either float around or have a much larger, "blobby" focus. I tested each driver individually for inverted phase compared to one another and they all sound like they're connected and configured correctly.
I have another set of 3-way DIY speakers that have three stacked spheres as the enclosure, with a traditional crossover, and their imaging is super precise no matter how they're placed. Wondering if my issue is due to the cabinet/baffle diffraction, room placement, driver distance, the active amp (Acoustas AC650), or something else.
Picture for reference:
Like I said, I've moved them out, wider, toed in, sat really close or far away, nothing really changes the poor imaging. Any advice would be great!
