With the wood and metal and all those wires, it seems to me that you would be setting yourself up for alot of sympathetic vibrations. Who knows though, it could be "good vibrations"
Semi-DIY:
A monitor stand adapted to attach to a different sort of monitor. About $35 each.
Turns out there are mounting holes on these Genelecs at 76mm, VESA has holes at 75mm, this is a discrepancy that is quickly overcome with the right drill bit.
I have been considering something very similar for my iLoud MTMs; they have a 3/8" threaded insert in the bottom and they are currently sitting on table top mic stands. However, i've just bought a standing desk and i've been thinking about fixing them to the desk more securely and freeing up some more desk space. I found these VESA to mic adapter plates, but I think they're a bit expensive for what they are... https://vivo-us.com/products/mount-v00mic
If you have a drill, just get a standard 3/8" bolt and any VESA mounting plate and just drill a hole for the bolt and you should be good, no? That's basically what this adapter is...I have been considering something very similar for my iLoud MTMs; they have a 3/8" threaded insert in the bottom and they are currently sitting on table top mic stands. However, i've just bought a standing desk and i've been thinking about fixing them to the desk more securely and freeing up some more desk space. I found these VESA to mic adapter plates, but I think they're a bit expensive for what they are... https://vivo-us.com/products/mount-v00mic
If they have a flat base, something like this:
You could use a small G cramp:
Nice thing about shoe racks is they make them in 30 and 40 inch widths (vertical heights) to get speakers to ear level for seated tall people…..and they are cheap as chips.
wooden bar stools.
Granted, the drill bit I used for my "adaptation" was $60 by itself so this is one of those times when you need to have high expectations for future use to justify it...
Unfortunately I have to report I can't get anyone a discount there.
Not bad, but do make sure that the hardware is rated to take more than the full weight of the speakers. The VIVO stands I'm using are rated for a screen that weighs more than the Genelecs, but it was quite hard to get them to stay straight, I had to use a lot of muscle to tighten the bolt. I think this is because the weight distribution of a speaker is much further from the hinge than a screen's, so the torque ends up being a lot higher.Yes, this is what I was thinking, but not all the arms have VESA mounts that will rotate the full 90 degrees so the plate is horizontal. However, your project has emboldened me to do something similar... with a twist.
On my desk, I have 34" monitor, on a gas lift stand, connected to my personal Windows PC and to my work laptop (the monitor has built-in KVM switch). I also have personal laptop which runs Linux. So I am thinking it would be nice to have an MTM and laptop mounted on a stand on each side of my monitor.
So I found this monitor and laptop stand on Amazon UK which has an addition 50% off making them £19.99 (~$25)... https://www.amazon.co.uk/dp/B07DWM9WNM
The VESA mounts on these do rotate the full 90 degrees, and it's the same brand as my monitor arm (so I know it's decent). I've ordered 2 (separately to get the 50% off on both ). If I don't like both arms on the poles I can simply remove one from one or both poles.
If you're willing to drill some holes in the desk:
Threaded Rod UNCVapormatic VLG5122 Threaded Rod Self colour 3/8
Vapormatic VLG5122 Threaded Rod 3/8www.carpentergoodwin.co.uk
Penny Washers - Repair Washers M5, M6, M8 and M10 Mudguard Washers | eBay
Mudguard Washers. M8 – 25mm or 38mm or 51mm OD. M10 – 30mm or 38mm or 51mm OD. M6 – 20mm or 25mm or 38mm OD. M5 – 20mm or 25mm OD. Penny/Repair Washers BZP in various sizes. Penny/Repair washers BZP.www.ebay.co.uk
1/4 5/16" 3/8" 7/16" 1/2" 5/8" 3/4" UNC ZINC PLATED NYLOC LOCK NUTS NYLON INSERT | eBay
UNC NYLOC NUTS. ZINC PLATED STEEL.www.ebay.co.uk
