Diy speaker project - 2 way bookshelf
biyer
Hi Everyone,
Firstly I would like to thank a lot of people on this forum.
I just completed my first diy 2-way bookshelf speaker project. Please could you share your opinion and what I can do better next time.
Have been looking for a project to build for some time. I got an idea after I came across the post
The above driver is still being manufactured in India (by Peerless Audio which is currently not related to Peerless Fabrikkerne but bought over assets of peerless's Indian subsidiary)
Then came found another tweeter from peerless which was apparently used by the Energy Connoisseur series.
https://electrocarts.in/product/25mm-silk-dome-tweeter-low-fs-neo-system/
That's how project code name Alpha/Energy was conceived.
1. I started by measuring the TS parameters myself by using test jig (https://audiojudgement.com/measure-thiele-small-parameters-using-free-software/)
2. Then designed enclosure in WinIsd . The volume is approx. 9.14 liters with port diameter 2.25 inches, port length 6.2 inches tuned to 65hz
Enclosure was built using 18mm HDF wood which was scraps found at local CNC shop.
Dimensions are 7.5W x 10D x 13H inches.
3. Measured the Drivers in box and captured FRD and ZMA. I also captured the woofer in different axis's to find cone breakup. Used Dayton imm-6 mic.
4. Used xsim to design crossover.
5. Put everything together and measured the response
On axis 30.40.60 and 90 degree response
Near Field port (RED) , Woofer (BLUE) and Tweeter (GREEN)
the cabinet/ port resonance around 800hz needs to be addressed.
Pics
I will post proper pictures once I am done painting.
Finished Painting using Granotone Speaker Paint.
The Total Cost of project was under 190 $ (17000 INR)
Overall I am very happy with the project. They sound better than my Wharfedale Diamond 9.2. I am caught up with some family responsibilities will add additional measurements once I find time.
I am currently powering these using a TDA1521 board based audio amplifier which I built for testing.
Is it enough to just measure horizontal directivity for nearfield use? sub 3 meters
Also tried stuffing the port, like them sealed. planning to add a diy sub
have made few modifications. I have sealed the port and rounded the vertical edges of the baffle.
The orange response is without rounding
the blue response is with.
Both responses have 1/48 smoothing applied. Have deliberately
The peak at 4khz has almost vanished and the trough near 7khz has reduced. Slight more wrinkly response overall.
Next project I will be estimating baffle diffraction and rounding effect in Vituixcad.
Step Response
ETC
Still trying to understand how to interpret impulse and step response in terms what's a good response, Is this really that important?
Distortion :
CSD
Still need to take nearfield measurements, aliso will retake measurements with vertical and horizontal off axis measurements as well
