DIY speaker killed my amp?
ATB
VA, USA
Background: Many years ago (15+), I assembled a set of speakers based on the Zaph Audio design that used Seas metal drivers. I was happy with how they came out and sounded. I didn't do any fancy testing of the crossovers or final speakers, only made sure sound came out of all 4 drivers and both finished speakers sounded about the same. They have to date remain the pair of speakers I most enjoy.
I currently am using them in my living room for a 50/50 combo of TV and audio. Wiim Ultra with inputs from HDMI arc(TV) and an AirportExpress via optical (audio) with amplifier duties via a used Rotel RMB-1066 I picked up a number of years ago that was gathering dust waiting for me to get around to trying to build a pair of LXmini+s.
I was using 4 of the 6 channels of the Rotel (A and C) bridged to 2 channels for the past year or so. Last week, I noticed the left channel was significantly quieter than the right. I did some testing and determined it was the left (A) channels of the Rotel. During part of the testing, I had the left speaker connected to the B channels of the Rotel both bridged and unbridged. When I was done, all 4 A and B channels seemed to be no longer working. Note I was careful to never let the speaker leads from the amp touch while the amp was powered.
In case it was something wrong with the speakers and to get audio for the TV room back, I put the speakers off to the side and connected an even older pair of Boston Acoustic CR6s I have had since college connected to the still working C channels of the Rotel.
What is my question? Did the left Zaph speaker kill 4 of the 6 amp channels? I recall an old Kenwood reciver I had also had the left channel die slowly - it would be out and then of I turned up the volume it would come back. It eventually died completely.
I assumed I may have either mis-assembled one of the crossovers, a crossover component died over the years, or one of drivers had died. For the first time in 15 years I decided to do some slightly more detailed testing and ordered a Dayton Audio DATS v3 to run an impedance sweep of both speakers. I assumed I would see either really high or near zero ohms for some portion of the frequency band.
This is what I got:
Compared to the original Zaph measured response:
To my very untrained eyes, my speakers look to be close enough to the design to be okay and not the problem. Would the forum agree? Anything else I should check before potentially killing another amp? I do have a UMK-1 mike and have used REW for some subwoofer tuning in my home theater if that would be worthwhile.
Impedance here doesn't look low at all, and you don't mention playing super loud, so I doubt it was the speaker.
How old is the Rotel? Capacitors can go bad after about ~20 years and cause amps to stop working in gradual and then sudden ways. This seems more likely than the speaker putting undue strain on the amp.
Never play very loud. Amp is probably 20 years old - it's been with me at least 5 years when I got it off eBay. I may look into having it repaired locally.
Very happy if my speakers are still functional!
Bridging does increase the power & current, putting more stress on the amplifier. Often, the impedance can't be as low when bridged.
Very true, but these don't look like they went much below 7 ohm, not exactly a crazy load...
Stuff made from 2000 to 2008 randomly used caps that were made incorrectly and are super prone to failure. Just about every computer monitor made them had failed power supplies, as well as many motherboards in all types of electronics. Those all in one systems always failed, DVD players, AVR systems had huge failure rates from those years. I've seen popped Elan , Panasonic and tons of lesser know caps go bad in everything. Built before 2000, still probably good, even 70s stuff has less chance of failure.
Yep, I replaced some caps in my GE refrigerator and an HD TiVo in the early naughts that was preferable to junking. I didn’t even make the connection this Rotel amp is from the same era.
For now, the Zaph speakers are back and the Rotel has been replaced with a WiiM Vibelink amp connected via Optical to the WiiM Ultra . I used the oppertounity to re-run the WiiM room correction that has matured significantly since I first got the WiiM Ultra including being able to use my umik-1 w/ calibration file from my iPad.
I’m very happy with the results. Now back to music and movies. Thanks everyone!
Agreed. At impedance minimas, there’s hardly any phase angle too.
This is one of the easiest loads I’ve seen for a while. Bridged, its impedance is halved, but that new impedance is now on par with many of today’s modern “8 ohm” speakers with impedance minimas around 3 ohms. Nothing alarming here by today’s standards.
Edit: I just realized this was a 1mo old post. Sorry.
