DIY Purifi Amp builds
Does anyone know that this paragraph is also valid for when the user leaves the original binding posts and additionally solders on the SpeakON connectors?
Because if so, then I believe that SMD desoldering will limit most of Ghent's customers, and thus it really doesn't make sense to offer it with SpeakON by default.
Oh, I've seen some diy using the Eval1 that had 5 way binding posts. I thought the little holes were to screw in a 5 way "knob." I'm reaching for vocabulary here. I mean this part:
EDIT: I see now, in Amir's review the 5 way binding posts were soldered to the pcb where the banana plug receptacle thingies are usually on the Eval1. Thank you for the information, @hyperknot!!
What are the best ways to purchase the EVAL1 and Hypex PSU for USA customers? I have seen reference to discounted OEM pricing. Any details would be helpful. Thanks.
So, you paid about $759.23 for the EVAL1. The Ghent Case with Wire Harness is $250. The Hypex SMP1200 is $260.24. That brings the total to $1269.47.
Correct, I also direct ordered from Purifi in Denmark and Hypex in the Netherlands (and Neurochrome in Canada, quite an international build!). Arrived same week I ordered it.
It's not "cheap", but it certainly is state of the art as far as Class-D amps go.
I paid more, I bought the cable harnesses for the SMPS1200 and EVAL1 too from their respective manufacturers. I'll still end up missing one cable somehow.
I just got email from Ghent!
This is amazing news! Also the harness for 35 USD is a steal.
I'm gonna buy the harness. Just in case my problems stem from the homemade one I made for the aux power. I'll also have to send the SMPS back to Hypex. I will also reach out to Purifi to see if there's a problem with the Eval1.
The only thing I did to the Eval 1 was to remove the standby switch, so I don't see how that could have caused a short.
It should be noted that you can buy the VTV Purifi Amp for 969 so if you're not married to the idea of the eval 1, you can get an assembled amp for less than the price of the components. Or even as a source of components for a diy project it might be a good deal.
I asked about the SpeakON and they said that they just install it:
You need to solder leads up from the EVAL1 output pads up to the speakON tabs. Or, you could assemble jumper cables with Z plugs inserted from INSIDE the case to Quik connect terminals for the tabs.
The feedback path is completed by the DELTRON-style sockets on the EVAL1 if you leave them intact.
What cable are you missing with the Ghent harness set?
When you unsoldered S1, did you add a jumper to enable the amp, OR fit the /AMPON wire between the EVAL1 and the SMPS?
The feedback path is completed by the DELRON sockets on the EVAL1 if you leave them intact.
Thanks! So do I understand right that a normal person doesn't ever need to do some kind of SMD desoldering if they prefer SpeakON? Just 2x2 wires to solder and that's it?
So the DIY bill of materials is:
- Ghent case + harness: 250 usd
- Purifi EVAL-1 kit (I/O board + 2 amp modules): 760 usd
- Hypex SMPS1200A400: 215 usd
Total: 1,225 usd
While an assembled amplifier costs:
- Apollon: 1,780 usd
- Audiophonics: 1,240 usd
- March: 1,600 usd
- VTV stock buffer: 979 usd
- VTV Sparkos Pro opamps and regulators: 1,350 usd
All prices converting currencies in Google, and excluding both VAT and shipping (DIY has to pay for 3 shippings).
Notice that the VTV amplifier uses essentially the same case, SMPS, amp modules but with a stock buffer, and is 20% cheaper than DIY.
I guess it makes sense to DIY for the experience and pride of assembling, or to add any special parts that the manufacturers don't have. Because considering price and effort, it is not worth it, at least in my opinion.
Already did that. I bought the VTV Purifi Amp a couple of weeks ago. I made a video.
It looks like VTV will also sell EVAL1 amp as well for an attractive price. From a cost perspective, it looks like DIY is NOT the way to go at this point.
