Would highly recommend you use nylock or nylon nuts, or at least threadlock on those nuts. Not great to have one of them fall into a powered circuit.
Good idea, just ordered a bunch of M3 nylon locking nuts.Would highly recommend you use nylock or nylon nuts, or at least threadlock on those nuts. Not great to have one of them fall into a powered circuit.
SMPS standby will disconnect power from purify so using amp standby is not necessary.So I'm finally making some good progress on my build and have most things wired up. Last thing to figure out is standby functionality on the SMPS1200.
I want to use a latching push button on the front to toggle between standby and power on. My understanding is that sending a +12V signal to J5.1 and J5.2 on the SMPS1200 will put the smps and the Purifi amps into standby mode, and interrupting that signal turns everything on.
So I'll need to wire up the front switch to be normally closed, correct? I'll be using a screw down terminal to be able to send +12V to J5.1 and J5.2.
I know that typically an electronic circuit needs to be closed, or a loop if you will. J5.1 and J5.2 only take in +V. So where does the -V go?
Otherwise the amp works, or better said, the amp enabled leds come on.
GND can be taken from J5.5.
As you have a lot of space inside the enclosure, maybe it will be better to use additional relay to cut off the power instead of using SMPS standby? Smps1200a400 takes around 10W in standby mode and it’s quite a lot...
Shield and black need to be shorted together on rca side.Well, I figured out the power switch. Turns on with the power switch now
Hooked up the amp to my speakers and my Yamaha receiver with the RCA > XLR cable I had built myself. Hear this weird loud buzzing sound. I went, ugh, did I screw something up in the build?
Answer is yes, I did, but it was the cables. I must've gotten the wiring wrong? Because after testing the amp with my laptop > audio interface > balanced XLR > amp, it all works fine (and it sounds fine, but it's getting late so no serious testing yet).
Will need to figure out what I did wrong with my cables. I followed this schematic:
Maybe wires are shorting each other, no idea yet.
They do? I thought I didn't need to connect shield to anything on the RCA side per that schematic.Shield and black need to be shorted together on rca side.
Does anyone know how EVAL1 input impedance changes with the gain/bypass jumpers B1 & B2?
It will go from about 47k (94k diff) to 2.2k (4.4k diff)
The closed loop gain of the 1ET400A amplifier module is ~13dB, and the optional buffer/gain stage of the FE02 input board is ~14dB, so the EVAL1 gain is ~13dB/27dB (bypass/pre gain).
To drive the amplifier to full output power (1% THD), an input signal of ~1.8VRMS/9.8VRMS (~2.5Vpeak/13.8Vpeak) is needed (bypass/pre gain).
The input impedance of the FE02 input board is 2.2kohm/4.4kohm in bypass (1ET400A direct), and 10.2kohm differential for the buffer/gain stage. Single ended (connect pin3 of XLR to GND) input impedance is also 10.2kohm in pre gain mode.
Best regards,
Søren Bang Poulsen / Purifi
It has 2 47 K resistors at the input. I believe the circuit diagram is posted somewhere in this thread. So unless they have changed it recently.Hmm I've got different response from Purifi...
Congrats! Very nice build and finish. If I had moved forward with my DIY project it would have looked exactly like that, if my skills allowed.Finally finished my project!
Silly me, I didn't post my measurements with my previous post...It has 2 47 K resistors at the input. I believe the circuit diagram is posted somewhere in this thread. So unless they have changed it recently.View attachment 74310
Interesting.Silly me, I didn't post my measurements with my previous post...
That means they indeed changed the circuit. I'm wondering what was the reason for that change and how it can affect measurements (except potential issues with preamplifiers with high output impedance).
Can you post closeup pictures of EVAL1 board's preamp section? I'm interested if they just changed R14/R19 values or also something else.Silly me, I didn't post my measurements with my previous post...
Looks like the other resistors are same as before. R14/R19 are now 5.1K, before 47K. This will reduce/remove noise when there is no input connected. I may change those, I'm going to change gain with R17, so I'll do those at the same time.It's best what I have for now. Pictures are low quality as this area was not in "main interest" when picture was taken
I can take better photos toady evening.
