Block diagram for using relay board to enable / disable amp and light switch LED.
Purchased Items
Meanwell – IRM-30-12ST $15 to $17 u.s 12VDC power supply.-DigiKey supply house.
4 Channel 12v relay board sold by VOGURTIME Amazon $7.99.
Quentacy 19mm latching pushbutton switch with 12v LED $9.99 Amazon.
SYSLY IDC 2by5 male header breakout terminal block $13.99 Amazon.
10 pin 3m cable -parts bin.
Screw terminal - parts bin -Homedepot or Lowes.
Ik resistor parts bin.
Jumper from SMPS J5.1 SHE-001T-po.6 6X2 12inch.- Digikey supply house.
If you want a power on switch and remote on you need a “OR” function i.e. remote on OR power switch on. If you only need switch on then you only need a two-channel relay board.
If you have any questions I will try to answer them. Refer to picture to help identify items.
Hello JimM,
Thank you for posting your amp build - it is really helpful!
I have a question, please, excuse me if it is a very silly question - I come from software development background and I am trying to learn electronics:
- could I simply get away by supplying +12V directly to the SMPS Standby J5.1 input? For example, something like this:
^ either the switch or the relay controlled by the external Trigger would interrupt the standby circuit to wake the SMPS up.
I could go even crazier and break the 220V circuit before the AC/DC power supply - in this case the 12V AC/DC power supply would be fully switched-off when the amplifier is operating. Or am I wrong?
Does the J5.1 needs to be pulled down when SMPS is not in the stand-by mode?
I also have a similar question regarding the relay and the AmpOn LED - 100mA max through J4.6 should be enough to directly power a 20mA LED?
I would be very thankful if you spared some time to provide an explanation.
Thank you!
G.V.
