What gets you the pop free start of you're using the amp enable output from the SMPS to drive the led on the front? Or is it controlling both the LED and the Eval1 board. Clearly I'm misunderstanding something.Got 12 volt remote, and or switch connected to SMPS stand-by/enable and feedback on switch LED with amp enable all off the SMPS works great, turn and turnoff pop free. Decided to use SMPS amp enable J4.6 as a feed back for LED turn-on rather than EVAL1 ready signal, a it's cheaper to replace SMPS than EVAL1 if something did not go right, and it will be obvious if the amps don't come on. Used a 4 channel relay board with opto -coupler inputs, wiring is a mess so will design and build a prototype board to see if can clean up some of the wiring and simplify the circuity. Driving my 3way Jeff Bagby design Kairos speakers I think I like this combination even better than than the Maggies so great project. Thanks again for all the input.
JimM
JimM
You could use something like my Modulus-86 or Modulus-186 with a ±24 V power supply and have plenty of power available for the horn drivers. Just saying.
I used the relay board as it was convenient with screw terminals to prove the concept. The relay board has optocouplers for input so you get isolation on the input side and the relays provide isolation on the out put plus you get either normally closed or normally open for polarity.
You could also use something like my Guardian-686: https://neurochrome.com/products/guardian-686The pop free I believe is a function of the SMPS turn on and turn off i.e. the SMPS enable. I used the relay board as it was convenient with screw terminals to prove the concept.
Block diagram for using relay board to enable / disable amp and light switch LED.
Purchased Items
Meanwell – IRM-30-12ST $15 to $17 u.s 12VDC power supply.-DigiKey supply house.
4 Channel 12v relay board sold by VOGURTIME Amazon $7.99.
Quentacy 19mm latching pushbutton switch with 12v LED $9.99 Amazon.
SYSLY IDC 2by5 male header breakout terminal block $13.99 Amazon.
10 pin 3m cable -parts bin.
Screw terminal - parts bin -Homedepot or Lowes.
Ik resistor parts bin.
Jumper from SMPS J5.1 SHE-001T-po.6 6X2 12inch.- Digikey supply house.
If you want a power on switch and remote on you need a “OR” function i.e. remote on OR power switch on. If you only need switch on then you only need a two-channel relay board.
If you have any questions I will try to answer them. Refer to picture to help identify items.
The Guardian-686 is for use with amplifiers that have balanced/bridged/BTL outputs, such as the Hypex/Purifi amps. You can build it as a stereo or dual-mono board as well.Very interesting. Is there also a kit for the stereo/dual mono version (such as a mouser part list)?
Maybe a definition issue here, but as far as I remember, the "minus" output of Hypex/Purifi amps is grounded. So not what I call balanced/bridged/BTL.The Guardian-686 is for use with amplifiers that have balanced/bridged/BTL outputs, such as the Hypex/Purifi amps.
If so, they would have said so in the data sheet. Just as they do in the Purifi data sheet. I design by the information in the data sheet. Not by "so-and-so on the internet said" or assumptions. You're free to design your circuits differently.Unless the NC500 OUT- is not to be connected to GND because it's internally connected .
Let's stop the discussion here. I have my own ethics and will stick to them.If so, they would have said so in the data sheet. Just as they do in the Purifi data sheet. I design by the information in the data sheet. Not by "so-and-so on the internet said" or assumptions. You're free to design your circuits differently.
Tom
