True that. But at the same time, I would also think that the average DIYer would be interested in having an amp that doesn't blow the speakers if you breathe heavily on the volume control.
Well, who wants to blow the speakers if you breathe heavily on the volume control?
Why anybody with 95+ dB efficient speakers is using Class D in a residential setting is beyond me. For PA use, yes. But in a living room? That blows my mind (and ears).
TBH I have that sensitivity because in my experience such speakers are more transparent and dynamic even at ludicrously low volume. I am using concentric compression driver for mids and highs into Le'cleach horns, and this level of detail and transparency is not achieved through any other means in my experience, not even AMT tweeters and ribbons. This is further refined into the upper treble by Visaton TL16H aluminium horns (not high end Fostexs, but again I am using them only for >= 10Khz).
The main "problem" is that those drivers and horns have a very high sensitivity. In fact, the tweeter part of my concentric BMS compression driver has a sensitivity of 108Db, so I use an autoformer to reduce the sensitivity by about 12Db. I also have Dayton Audio PA-460-8 woofers, and those for some reason react better when the amplifier has a very high damping factor... they sort of "sense" the potential power of the amp. I do not need all that power that the 1ET400A provide, but the sound is so clean and transparent, with the smoothness usually associated to SET, that I do not care much. I also still use less total power than a, say, 8W SET, because the latter would probably consume 20W (constant, because class A). So I tick the following boxes: [x] I do not need to multi amp (yet) because the amp covers nicely everything and can provide the right behaviour for any segment of the audible spectrum; [x] I have extremely transparent sound; and [x] I use little power.
Maybe one day I will move to a little 2A3 PP Or maybe just single ended.
True, if I dared drive the amps close to clipping only the woofer would survive, and my windows would shatter. I would probably also end up permanently deaf.
