DIY Mono Amplifier Build with 3e Audio 480-1-29A and MicroAudio SMPS600-R3
Kanaz
Hi everyone,
I wanted to share my updated DIY mono amplifier build using the 3e Audio 480-1-29A amplifier module with the MicroAudio SMPS600-R3 power supply.
I previously built a similar amplifier using a Mean Well UHP-series power supply, and that build worked well overall. However, I had one issue: when turning the amplifier off, there was a fairly noticeable pop noise.
With the MicroAudio SMPS600-R3, the behavior is much better.
It seems to have a soft-start / standby-type control behavior. When turning the amplifier off via the SWT connector, the amplifier module does not shut down abruptly. Instead, it seems to power down more gradually after a short delay.
Because of this, the turn-off pop noise is almost completely gone. I can only hear a very tiny sound if I put my ear very close to the speaker.
MicroAudio also confirmed to me that it is okay to leave the power supply working in standby mode. So in my current setup, I keep AC power connected and use the SWT connector for ON/OFF operation.
I have seen different reports about pop noise with the 480-1-29A module. Some users say they have no pop noise at all, while others seem to experience it. In my case, I recently bought eight 480-1-29A modules, and with my normal power supply arrangement, all of them produced a pop noise when switched off.
Because of that, I would normally need to add an external relay circuit. But with the MicroAudio SMPS600-R3, I do not feel that a separate relay is necessary.
Parts used​
  • Amplifier module: 3e Audio 480-1-29A
  • Power supply: MicroAudio SMPS600-R3
  • AC inlet: Furutech FI-06(R) NCF
  • RCA input connector: Furutech FT-903(G)
  • XLR chassis connector: NEUTRIK NC3FD-LX-HE
  • Binding posts: Monosaudio BP451G
  • Power switch: NKK S331
  • Power LED: BIWAR MPC6-1WD12V
  • AC internal wiring: Oyaide 3398-16
  • DC wiring from PSU to amplifier module: Oyaide 3398-14
  • Speaker output wiring from 480-1-29A to binding posts: Oyaide EXPLORER V2 2.0 sq
I also installed NEUTRIK NC3FD-LX-HE XLR chassis connectors on the amplifier chassis. However, my current DSP only supports RCA outputs, so the XLR connectors are installed mechanically but are not wired internally at the moment.
About the 3e Audio modules​
I should also mention my recent experience with 3e Audio.
Recently, I bought two additional 480-1-29A modules. Before placing the order, I specifically asked them to send modules with the same capacitors, because I did not want mixed capacitors in a mono-mono stereo system. They replied that this would be okay.
However, when I received the modules, one had Rubycon capacitors and the other had KYB capacitors. I requested an exchange, but they refused and repeatedly said that there was no problem because the capacitance values were the same.
Technically, that may be true. But personally, for a mono-mono stereo system, I did not want the left and right amplifier modules to use different capacitors. I explained this, but my request was not accepted.
The response time was also quite slow. To be honest, I was disappointed, especially because I had already bought eight 480-1-29A modules and also two A7 Mono amplifiers from them.
I also bought a pair of 3e Audio A7 Mono amplifiers recently, and one unit included a user manual while the other did not. This made me feel that their overall QC and packing consistency could be improved.
In the end, I bought additional Rubycon capacitors myself. Since I was replacing them anyway, I chose a higher-spec Rubycon version with 1800 µF capacitance and replaced the capacitors myself so that the left and right amplifier modules would match.
About MicroAudio​
My experience with MicroAudio was completely different.
Even before purchasing, I exchanged several emails with Sami at MicroAudio. He shared photos of the SMPS production process and allowed me to choose between several small configuration options and fine adjustments.
I was very impressed by his kindness, speed, and the way he handled communication.
Even after I received the power supplies, he continued to check in with me. He asked whether the products had arrived safely, whether I had completed the amplifier build, and whether there were any problems after assembly. Even when I did not reply immediately, he followed up to make sure everything was okay.
This level of support was genuinely impressive.
Sound and usability impressions​
As expected, the amplifier built with the Mean Well power supply and the amplifier built with the MicroAudio power supply feel different in actual use.
The biggest difference for me is not only the sound impression, but also the usability: standby operation, turn-off behavior, and pop-noise control are much better with the MicroAudio SMPS600-R3 in my build.
Of course, this is not a measurement-based review, and I understand that some ASR members may not like this kind of subjective impression. But as a DIY builder, I am very satisfied with the result.
The amplifier is clean and quiet in my system. There is no audible hiss, no significant pop noise, and the amplifier is comfortable to use.
As you can see from my photos, I originally liked vintage speakers and tube amplifiers. However, I do not have a fixed bias against modern measured-performance-based audio. These days, I am also building a speaker system based on many ASR-style reviews and measurements, and I am enjoying it very much.
Overall, I am very happy with the MicroAudio SMPS600-R3 in this DIY amplifier build.
I plan to do more DIY builds using MicroAudio products in the future, and I will post another review after my next project.
Thanks for reading.
I also bought two 480-1-29a and two 260-2-29a boards recently. The former are powered by 500W toroidal transformers at 37VDC. No pop noise turning on-off. The later are powered by one 600W Meanwell LOP-600-36. In both cases, there is no popping noise on or off. Could this related to the use of lower voltage (36V)? Or, the use of 10K passive pot?
Anyone without one might buy a 'scope - always useful. Mine was £26 on AliX - crazy cheap, but good enough for casual debug.
Sami is the GOAT of power supply's in the diy space. When I still didn't know anything he graciously exchanged countless emails answering the dumbest questions i had that I'm sure he's answered a thousand times and is sick of answering but that's only my guess as you couldn't tell at all from his replies, and this was all before i had even spent a dime on his website. because of that I've since purchased 4 or 5 others and won't even look anywhere else for my smps power needs. i honestly don't like to give free advertising for products online but between how good the products are and how excellent the customer service is i don't mind giving him free advertising one bit.
@Kanaz which amp sound you like more, the one you built or A7 mono? Please share more details if possible, thanks
Yes, I haven't done any measurements or objective comparisons, but to my ears, the version I built using the Micro Audio SMPS sounds better.
@Kanaz
Thanks for detailed info.
Team,
Seeking an advise, please guide : When planning 3e audio A7 Mono Blocks (with out default adapters) Could you please advise specific Micro Audio SMPS model that best support and recommended to use for these... as this unit is capable of 48V 10A and also 52V 9A as well....
Also, I am struck on the options to pick between below while selecting the SMPS specific for A7 Mono units.
Output Voltage (Dual Rails)
AUX Voltage (Regulated)
Driver voltage
Standby power supply voltage
Please advise. Thanks in advance.
@Kanaz
자세한 정보 감사합니다.
팀,
3e Audio A7 모노 블록 앰프(기본 어댑터 제외)를 구성하려고 하는데, 이 앰프에 가장 적합하고 추천할 만한 Micro Audio SMPS 모델을 추천해 주시면 감사하겠습니다. 이 앰프는 48V 10A와 52V 9A 두 가지 출력 모두 지원합니다.
또한, A7 모노 유닛에 맞는 SMPS를 선택할 때 아래 옵션들 중에서 어떤 것을 골라야 할지 고민입니다.
출력 전압(듀얼 레일)
보조 전압(조정됨)
드라이버 전압
대기 전원 공급 전압
조언 부탁드립니다. 미리 감사드립니다.
최종 결정을 내리기 전에 Micro Audio의 Sami에게 연락하여 실제 가정용 전압을 포함한 시스템 구성에 대해 상담하는 것을 권장합니다.
May I know,
A7 Mono's are you using with 48V 5A or 10A power adapters?
Did you check and compare how A7 Mono sounding when powered through Micro Audio SMPS ?
Seeking your feedback and observations/advise between : 480-1-29A modules build with Micro Audio SMPS vs A7 Mono with Micro Audio SMPS vs 480-1-29A modules with received A7 Mono power adapters
Also, about your mentioned point: "I also installed NEUTRIK NC3FD-LX-HE XLR chassis connectors on the amplifier chassis. However, my current DSP only supports RCA outputs, so the XLR connectors are installed mechanically but are not wired internally at the moment."
If we need to plan both XLR and RCA output can we take output directly from the module board? or do we need to have additional output board that supports such dual connections and selector switch....
Please advise... thanks in advance.
May I know,
I couldn't notice any difference in sound quality between the 5A and 10A power supplies. However, I did feel a difference in power and drive. Please keep in mind that this is purely my subjective listening impression, not something I have verified through objective measurements.
If you want to switch between RCA and XLR inputs, you will need a separate input buffer board. As far as I know, using both inputs simultaneously is not supported by the specifications, but this would need to be confirmed.
I have now switched to using XLR exclusively because of the difference in input gain.
I needed a lower input gain, and as far as I know, the A7 Mono has gain settings of 21 dB (Low) and 26 dB (High) for RCA, while XLR has a gain of 20 dB. My understanding is that lower gain generally helps reduce audible noise.
I also installed a relay to address the turn-on/off pop noise. Since installing it, I don't normally experience pop noise.
However, audible hiss can still occur with highly sensitive speakers or DIY active speaker systems that do not have internal passive crossover networks.
In my experience, this applies to both the 480-1-29A amplifier module and the fully assembled A7 Mono amplifier.
