Hello all. I'm on a mission to build a small device that I can plug a set of headphones, that include a mic, into to test if the left channel audio, right channel audio, and mic to see if they are working. I'm rather new to the engineering portion of creating something like this, but have no issues building, soldering, 3D printing cases/housings, etc. If anyone has knowledge or thoughts on what would be needed, I would really appreciate some help. Thank you in advance.
Tester Requirements
Tester Requirements
- Input from an audio source to test left and right channel audio (phone or laptop)
- Could be 3.5mm or USB (open to an other ideas)
- Jack to accept the headphones that need tested, assuming a TRSS jack will be needed for this
- In order to test the mic I'm thinking that I should be able to speak into the mic and hear it back either in the headphones OR from a small speaker
- Powered via 5v or 12v wall wart style plug
- Also open to rechargeable battery pack ideas
- Volume knob
- The headphones have a built in volume control switch so not sure if a knob would be needed
- Small speaker
- If not too difficult it would be nice to have a DIP switch or toggle to be able to output audio from the speaker OR to the headphones
