alto
- Joined
- Oct 2, 2021
- Messages
- 50
- Likes
- 7
I'm toying with the idea of building my own multichannel class D power amplifier as retail offerings I'm finding are not a great fit, or very expensive.
What I'm looking for is basically a power amp to drive the channels listed below with suitable power for the different needs, in one box.
I recently came to think of using ICEpower modules for the whole thing, previously I've been looking at Purifi class D modules, and I have a couple of mono blocks with 1ET400A's, but they are far more expensive than ICEpower when looking at this larger number of channels to drive.
Here is the breakdown, a total of 8 channels at a minimum:
I naturally have some questions about this as well;
- Front L/R - ICEpower 700AS2, 2 x 350W @ 8Ω
- Center - ICEpower 200AS2, 2 x ~200W @ 8Ω
- Surround L/R - ICEpower 200AS2, 2 x ~200W @ 8Ω
- Rear Surround L/R - ICEpower 200AS2, 2 x ~200W @ 8Ω
- Subwoofers - ICEpower 1200AS2, 2 x ~1200W @ 3Ω
- Are the ICEpower modules good enough for the non-subwoofer channels, I've seen varying comments on how they've not been the best in the past, but I've also seen it stated that their newest range is actually very good?
- Should I consider some other modules as well, I've looked around but found that the ICEpower ones are nice since I can get them one by one with integrated PSUs as well. This means that I don't have to get all the modules immediately and can instead expand the number of modules as I go.
- Where would I be able to find a case suitable for this (I'm in the EU)? I would want to keep it as compact as possible, but can compromise to fit extra fans etc in there if needed. I'm also considering the possibility to 3D print brackets for the amp modules internally so that they can be installed vertically to save on space.
