- Joined
- Jan 15, 2018
- Messages
- 295
- Likes
- 676
Hey ASR - wanted to share a project I just completed. I am a "tube guy", back in January I decided I was going to start building my own gear. That began with a 6A5G SET 3WPC speaker amplifier, which turned out quite well I think. 3 WATTS, WUT?! My speakers are 6ohm 98dB/W in a small room, I am living a happy flea-watt life.
But what I am sharing here is my second effort, a dedicated headphone amp. I know tubes aren't exactly this forum's cup of tea, I think this build will be a bit more palatable, measurements-wise, than my 6A5G amp (which uses an unreguated CLCLC PS and some super vintage tubes that I believe have some degree of heater-to-cathode leakage). It features a cascode MOSFET CCS-loaded 6J5 input stage, followed by a cascode MOSFET CCS-loaded 45 parafeed output stage. Mains transformer is a custom job by Sowter to my spec, OPT are Sowter 8983. Filament regulators are Rod Coleman's, coupling and parafeed caps are Rike Audio S-Cap 2 (paper, poly, aluminum, oil). Power supply is a single rail CLCRC.
Here is the schematic, although it is not comprehensive. Parafeed capacitance was determined experimentally by taking FR sweeps of various capacitances (courtesy of cheap Solen caps), along with subjective listening impressions. Ultimately decided on 6.6uF made up of two 3.3uF in parallel.
Bias points:
6J5 B+: 380V
6J5 plate to cathode: 200V
6J5 cathode: 6.2V
6J5 plate current: 8.5mA
45 B+: 398V
45 plate to cathode: 206V
45 cathode: 35.5V
45 plate current: 35mA
Here are some shots of the interior. Bottom plate is perforated aluminum sheet for ventilation.
Here is a FFT of the left channel at 350mV into 300ohms. I've traced the residual 60Hz noise to capacitive coupling within the mains transformer, reaching the signal output via the filament regulator. It's a bit worse on the right channel. Regardless, it is inaudible to my ears, so I'm letting it go.
And the frequency response.
Thanks for checking it out!
Bias points:
6J5 B+: 380V
6J5 cathode: 6.2V
45 B+: 398V
45 cathode: 35.5V
