306xx
This guide explains how to build a speaker with an aluminum enclosure. I designed the speaker using the waveguide for the SB26ADC made by @augerpro . Thanks to @augerpro for releasing all the drawings so that I could design the speaker. I hope this guide can inspire people who want to design their own aluminum enclosure speakers in the future.
PDF link: https://drive.google.com/file/d/1hTBLKORgGTOltmUg4CpEhTOgF5y6VoL5/view?usp=sharing
1. What to bring
https://docs.google.com/spreadsheets/d/1asfNiGf8bWuCD1tm__xDpQFnzZ7Du6s3C4IFWUEyy0k/edit?usp=sharing
Purchase all the supplies. Since this guide is made in Korea, the purchase links only work in Korea. You will need to search for suitable replacement parts yourself. There are drawings of the parts in the purchase link, so you should be able to find a replacement.
For the amplifier, you can buy any amplifier other than the Fosi V3. (You only need to match 4 channels)
For the aluminum CNC parts and 3D printed parts, you will have to make them yourself using the drawings or contact a machinist.
The final price depends on the machining costs, and I spent around $2000 for everything.
2. Machining
CNC drawing files: https://drive.google.com/file/d/1vK7v80REkIuRLbBdPThlD5r7apYcPClw/view?usp=drive_link
3D printing drawing files: https://drive.google.com/file/d/1ley7UBcsolubH278k8h1brl-dyQTPoFo/view?usp=drive_link
The README file in the zipped file explains the machining method and quantity.
Do your own aluminum machining and 3D printing as you see fit.
3. Assembly
① Attach the waveguide to the front panel. At this time, attach foam tape between the waveguide and the panel to prevent unnecessary vibration. (8 x M5-10mm wrench bolts)
② Disassemble the SB26CDC tweeter and mount it on the front panel. Apply foam tape between the waveguide and the front of the tweeter, and also between the aluminum bracket and the back of the tweeter. (Aluminum bracket, 2 x M4-60mm wrench bolts, several washers)
③ Mount 3 HBKTST5 and 1 HBKTST6 on the side panel. (3 x M5-10mm wrench bolts, 1 x M6-15mm wrench bolt)
④ Drill M8 tapped hole in the HBKTST6. (Use the hand tap set)
⑤ Mount four HBLCR5-S to the side panel. (4 x M5-10mm countersunk bolts)
⑥ Drill M6 tapped holes in the two HBLCR5-S located at the bottom of the side panels. (Use the hand tap set)
⑦ Assemble the opposite side panel in the same way and drill the tapped holes. (3 x M5-10mm wrench bolts, 4 x M5-10mm countersunk bolts, 1 x M6-15mm wrench bolt, 1 x M8 tapped hole, 2 x M6 tapped holes)
⑧ Apply foam tape to the back panel and join it with the side panels (4 x M5-10mm countersunk bolts, 2 x M5-10mm wrench bolts).
⑨ Apply foam tape to the top panel and assemble it to the enclosure. (4 x M5-10mm countersunk bolts, 2 x M5-10mm wrench bolts)
⑩ Mount 4 HBKTST5 brackets to the aluminum profile and assemble them to the enclosure. (8 x M5-10mm wrench bolts, 4 x LNTN6-20-5 profile nuts)
⑪ Apply foam tape to the front panel and mount it to the enclosure. Connect the wires before mounting. (4 x M5-10mm countersunk bolts, 2 x M5-10mm wrench bolts)
⑫ Apply foam tape to the bottom panel and mount it to the enclosure. At this time, apply foam tape to the bottom panel screw holes to prevent air leakage. (2 x M8-20mm countersunk bolts, 4 x M6-15mm countersunk bolts)
⑬ Install the SB15CAC30 woofer and the Neutrik NLT4MP-BAG spicon terminals and connect the wires. Since it is a 4-pin terminal, use crimp terminals to connect both the woofer and tweeter. (4 x M4-10mm countersunk bolts, 4 x M3-8mm countersunk bolts)
⑭ Attach the SB13PFCR passive radiator. (4 x M4-10mm countersunk bolts)
⑮ Assemble one more unit.
4. Tuning
① Place the measurement microphone at the same height as the tweeter as shown below and measure from 1 meter away.
② Measure the tweeter and woofer at the same location and set the time window to 5 ms. (The measurement position should be adjusted so that the first reflection is not heard within 5 ms.)
An example of the measured tweeter and woofer measurements is shown below.
③ Then, calculate the bass range measurements from the nearfield measurements of the woofer and passive radiator and add them to the existing woofer measurements. The detailed process can be found at the following link.
https://audiosciencereview.com/foru...ents-spinoramas-with-rew-and-vituixcad.21860/
④ EQ the tweeter and woofer measurements using REW's Auto EQ feature.
⑤ Apply 1.3 kHz L-R 48 dB/oct crossover filters to the flattened tweeter and woofer FRs.
⑥ Apply the resulting EQ and crossover filter values to the Minidsp 2x4 HD.
1. What to bring
2. Machining
3. Assembly
4. Tuning
