Connecting a subwoofer
The TDAI-1120 features a crossover function for optimal integration with
any subwoofer.
When connecting to a Lyngdorf BW type subwoofer, you connect the
analog output of the TDAI-1120 to the Bypass input of the subwoofer. In a
traditional single subwoofer setup, connect the subwoofer to the left analog
output on the TDAI-1120. For a stereo subwoofer setup, or if you have a
subwoofer which has stereo input, use both left and right analog outputs.
Warning! Do not connect the TDAI-1120 to a subwoofer with
High Level / speaker terminal inputs, as this will seriously
damage the amplifier. Your subwoofers will not play until the
setup has been finalized.
Subwoofer controls (not Lyngdorf type):
1. Phase adjustment should be 0°.
2. The subwoofer cut-off frequency should be set to the highest
possible frequency range.
3. Level should be set to 50% of the maximum.
