This week made a test setup with the York pico iso.
Setup,
- York pico iso
- 4 x stereo es9039q2m dacs
- 1 x 5V power supply
- 1 x 3.3V power supply
- 1 x +/- 12V power supply
After connecting the york pico to the PC with usb it was automatic detected.
Then started the york config tool, there was a message of a update was available .
The update could run from the config tool, within a view seconds the update was installed and the york pico was connected.
In the tool I set the output on 8 channel( 4 x I2S).
The dacs are connected according the york manual.
In windows in the sound config section it already showed 8 channel output.
Now I started Rew, configurated the output device and started the generator,
All 8 channels produced separate a good test signal.
Now I can use 192khz/32bit output sampling for every channel and have good THD + N specs of the es9039q2m dac.
Now I have to put all in a nice housing and start learning using Camilla and EqualizerApo.
I will use this software for 4 x 2 channel active crossover, dsp and roomcorrection.
Hi @
Koifarm,
I really like your 8-channel DAC build with the York Pico ISO!
Here is a question/suggestion:
Looking at your wiring schematic and the boards, I was wondering how you ensure that the Master Clock MCLK is in sync for all 4x DAC boards?
If I see it correctly, you're using the individual on-board clock per DAC, instead of the central MCLK from the York Pico. This might work technically if you measure each board individually, but if you really build a 3- or 4-way sound system, your DAC's could be out of sync (to my knowledge - I might be wrong though). This could lead to timing issues in the time domain. Have you measured the relative timing or phase differences between the four DAC boards?
You could try to use the MCLK from the York Pico board and route it to all 4 DACs. It might be necessary, to disconnect the DAC onboard clock.
I'm on a similar path with the York Pico ISO USB-C version and 3x instead of 4x DAC boards. I've removed the onboard clocks from my DAC boards and drive them all with the York MCLK.
Apart from this, I really liked your idea to stack the DAC boards in order to reduce necessary I2S wiring, as the signal is very sensitive to catch interference/noise (might try this approach as well).
Some questions to learn from you:
- Could you please post links to all your power supply components?
- How exactly have you done the wires, particularly the ground cables? Did you use only one GND cable per I2S batch? Or did you work with pairs of signal and GND (e.g.: BCK twisted with GND, LRCK twisted with GND, etc.)?
- Is the hose around your wires purely cosmetic, or does it have any GND/shielding capabilities?
- Is your audio signal completely noise free? Or do you get any hum, or high-pitched noise, etc. - especially when you connect USB from a computer?
I ask, cause I'm struggling with two things in my test setup:
- When the DAC is connected only to power supply, without the York Pico, I can hear a very high pitched noise/whine maybe at around 16 khz, when I place my ear directly at the horn tweeter. Once I connect the York, the above mentioned noise gets slightly amplified.
- Once the USB-C cable is connected from the Raspberry Pi5 (running CamillaDSP), I get a rhythmical noise...that goes something like tsch...tsch...
I got the York Pico ISO version, hoping that it would help to block the fairly typical USB noise - unfortunately it doesn't for me. I kept ISO GND separate from USB GND.
Was wondering if I should try a USB isolator like this:
ISOUSB211 High Speed USB 2.0 Isolator 480Mbps
I asked for the power supply, as it clearly has a strong impact on noise. I used this
Nvarcher LT3045 Dual-Channel Positive Voltage DC Stabilized Power Supply Low Noise, but it doesn't work well. I got it, since the chip should theoretically allow for ultra low noise - not working in my case. I need 5V for the DAC's and 3.3V for the ISO side of the York.
I also tried another boxed Aliexpress low noise 5V 120W power supply. This eliminates most of the noise, but I'm left with the above described super high-pitched whine.
My DAC boards:
Nvarcher ES9018K2M DAC Board I2S.
For context:
My intention is to first get the stock version up and running noise free. Than I'll get rid of the OPAMP and convert to tube output stage, similar to the old Lampizator Lampuceras
For now I use the
HiFiBerry DAC8x with the Raspberry Pi5. This works well, but I know what improvement a tube output stage on DAC can achieve
Below you see my current experimental setup. (The power cables of 2 DAC boards are not connected due to trouble shooting in these pictures.)
