Almost all of them show prices here (UK), although most are on 2-6 week delivery. Prices take a massive jump when adding a motor.
Thank you very much for checking. The Igus ones are the most reasonably priced hollow rotary actuators I am able to find so far. There are other ones I have found too, but much more costly (examples
here and
here).
I wouldn't recommend getting motors from Igus as there are more economical options. We'll need the
coupling housing and
a flexible coupling to attach a standard size stepper motor (NEMA 17 or 23), and we can use whichever stepper drive controller we want.
@Dave Zan
My goal for this week is to test out sound field separation using double spherical measurements. I think it is actually not bad. For the higher frequencies when we don't need sound field separation, if we measure with one single spherical surface (i.e. same
r for all points), the spherical Hankel and Bessel functions become independent of
r (since
r is the same) and will be combined into one constant (for each spherical harmonics order
n). Therefore, we don't need to solve for 2 coefficients but only 1, and thus halves the number of measurement points required. We shall see.
I have no experience with actual speaker testing. Do you know at what frequencies time-gated measurements become good enough?
For moving the mic in the
r direction, especially if we need only 2 positions, I think the simple school kid DIY method of using two syringes as (manual) hydraulic actuator may be OK?
Cheers!
