Tom Kamphuys
- Joined
- Feb 15, 2024
- Messages
- 84
- Likes
- 260
I've got an hypothesis:I gave you the hypothesis, some kind of glitch.
The bands in the directivity mean that we have large (reconstructed) sound levels in every direction. That means that the omnidirectional N=0 mode (Monopole) is large. Indeed the Monopole is large around 5800Hz.
The fit error is not worse than nearby frequencies, so the incoming Monopole has to compensate the large outgoing Monopole. It is, shifted 180 degrees.
Now it gets more hypothetical. The distance between the two spherical measurement surfaces is 3 cm, half the 5800Hz wavelength. I can image that results in a situation where the difference between incoming and outgoing sound is known, but not the incoming sound strength alone. That degree of freedom is not controlled/measured.
I plan on doing a measurement with a uniform distribution of r for the measurements, but that needs a good night sleep, some programming, bug fixing,...
