olds1959special
I did this to solve a ground loop issue. Is it safe? Will it compromise quality?
thanks, what about using a hum x ground isolator ?It is called "safety ground" for a reason.
Disabling it is forbidden, no insurance will pay in case of an incident and you will likely go to jail if someone gets hurt or killed.
Web search doesn't find anything for this term.hum x ground isolator
Morley Hum Exterminator Ground Line Voltage FilterWeb search doesn't find anything for this term.
If you mean some kind of audio isolation transformer inserted into the interconnection then yes, this is one way to deal with ground loops.
Unlikely. And this device doesn't show any safety approval labels so I'd be cautious.
This!It is called "safety ground" for a reason.
Not all devices need a protective earth a class 2 device may not have one for instance.Weren't SMSL DACs among those found to have "dummy" PE connections anyway? That may render the entire affair moot. Should be easy to check with a multimeter in continuity.
Also to reiterate what others have said you must never disconnect a protective earth if one is present.Not all devices need a protective earth a class 2 device may not have one for instance.
Ground loops through mains PE connections are indicative of badly designed equipment.
Which is kind of the entire point of Class II (double insulated).Not all devices need a protective earth a class 2 device may not have one for instance.
Find and Eliminate Ground Loops - Circuit Cellar
Everything had been fine with my home entertainment center—comprising a TV, surround-sound amplifier, an AM/FM tuner, a ROKU, and a CD/DVD/BlueRay player—until I connected my desktop PC, which stores many of my music and video files on one of its hard drives. With the PC connected, the speakers...circuitcellar.com
I am very suspicious of any device that interferes with a direct connection between safety ground on the mains cable and the ground connector on the mains socket. This looks much like a 'cheater' plug, which is a thoroughly dangerous device.Unlikely. And this device doesn't show any safety approval labels so I'd be cautious.
I agree that no one should ever bypass or remove a safety ground. However, your comments about insurance and being jailed are not correct. I've been in the insurance business for some 48 years now and have never seen a policy with a stupidity or accidental carelessness exclusion. Many insurance claims are paid following stupid mistakes by an insured that result in a loss. To void coverage, one has to get into areas where the actions were intentional - like arson, or setting up a situation to intentionally injure someone.It is called "safety ground" for a reason.
Generally yes. However, a lot of equipment has the audio ground tied to the chassis whether there's a safety ground or not. There may even be multiple connections of the audio ground to chassis, making it very difficult if not impossible to create a safe 'ground lift' facility.Correct me if I'm wrong, but does this issue mainly show up because of an inferior piece of equipment do to mixing of chassis ground and signal ground. ?
