Totally agree. That would really help in defining an engineering target.Suggest we need clearer ties between the benefits of different directivity features with their benefits.
Using specially made custom wave guide for the tweeter and a narrow baffle it is possible to have controlled directivity above around 400Hz.The quest for more/better directivity reminds me of a question from one of my mentors. Do you want more cheese on your pizza?
In my experience, more/better/controlled directivity is a feature without a clear benefit. Once you have god directivity, how much better is to have more or different?...
As you use a 15" driver I assume you want to control directivity to around 50Hz? 8C controls directivity above 100 Hz. You will need a very large acoustic filter to work at such a low level. I personally don't know of a material that works such low levels but mechanical filters may work.
How do you reduce 20Hz at 180 degrees by almost 10dB and where have you measured that?Here's a clearer difference with some contour lines drawn. It works pretty well in the bass range. There was no clear goal but trying to understand what happens practically speaking with these systems. I made 3 or 4 versions. Some more succesful than others.
Is that a simulation or measurements?
How do you reduce 20Hz at 180 degrees by almost 10dB?
How would that work on a baffle that is only 30cm wide at best? What kind of special is that waveguide to make that work?Using specially made custom wave guide for the tweeter and a narrow baffle it is possible to have controlled directivity above around 400Hz.
Just look at the D&D 8C frontHow would that work on a baffle that is only 30cm wide at best? What kind of special is that waveguide to make that work?
I am very interested to understand how you have achieved 10dB cancellation at 180 degrees and at 20Hz. Can you share us the details?Oh these are measurements. I don't have any software to simulate this.
ME Geithain produces similar results in their loudspeaker in a similar way.
Why? That waveguide does not control pattern down to 400Hz. It doesn’t need to, crossover is at 1250Hz.Just look at the D&D 8C front
I copied what I said below.Why? That waveguide does not control pattern down to 400Hz. It doesn’t need to, crossover is at 1250Hz.
So it is a closed box with extra high compliance? That is nothing different to any sealed box, which has an omnidirectional polar pattern below around 70Hz. Stuffed rockwool will simply increase the effective internal volume, nothing else.Basically the entire space behind the driver is absolutely stuffed with compressed rockwool, to the point where there's just eough space for the driver. The rest is what you see. There's no secrets.
Again: how does that give us directivity down to 400 Hz? The baffle step of the 8C is about 450Hz, so yes it does some pattern “control”, but at that point it already radiates 180 def. It won’t match the waveguide. So yes there is some control, but it’s much wider that one would like to see in a constant directivity system. In any case any baffle of the same size will do this, there is no magic in the D&D.I copied what I said below.
I think I made it pretty clear that I was talking about a waveguide for the tweeter.
The point of the stuffing is not the volume increase, but rather the slowdown of the sound wave so that they come out of the slots delayed enough to cause the cardioid effect.So it is a closed box with extra high compliance? That is nothing different to any sealed box, which has an omnidirectional polar pattern below around 70Hz. Stuffed rockwool will simply increase the effective internal volume, nothing else.
How and where did you measure the speakers?
How did you measure the speakers?
I was asking information about the the slots, which is the crucial part contrary to what @TimVG says, the "secret"The point of the stuffing is not the volume increase, but rather the slowdown of the sound wave so that they come out of the slots delayed enough to cause the cardioid effect.
Well, they were in plain sight, so from that sense, no secretI was asking information about the the slots, which is the crucial part contrary to what @TimVG says, the "secret"
