EDIT - what's below was a misadventure. The idea was basically this: Is there a way to estimate the on-axis driver offsets without moving the microphone? What I tried, which was basically a geometric approach in which the mythical acoustic center is modeled as a fixed point. Consistent with many discussion of acoustic center, and whether the concept is even useful, that model fails. Calculated from the difference between Purifi and DXT IR delays, as seen from a fixed microphone at the Purifi axis - even with a geometric analysis a bit better than what I have below - the DXT is only around 4 mm in front of the Purifi. Measured from IR delay at the respective axes, with careful positioning of the microphone at a replicable distance from the baffle surface, the DXT is 16.7 mm in front of the Purifi. Per the VCAD files I have from Directiva, this is in agreement with what was found by the folks who collected the Directiva dersign data.
So - I'm set up for measurements and wondering what others' strategies have been for preserving phase relationships of the two drivers. I've failed to find a clear discussion of the topic in the forums.
I'm using a Dayton EMM-6 with a loopback timing reference. So
as long as I don't move anything I have an independent reference. But I need to remove and remount the speaker to do "vertical" scans, and I think it's way better to capture each driver relative to its own axis, lest the data be valid only at one distance.
I'm wary of trying to move the microphone and get a sufficiently accurate distance with a tape measure, as a few mm can make a noticeable difference. My planned approach - but maybe there are better ones...
- Set up on the Purifi axis and collect data. Get an estimated IR delay, relative to the loopback reference, for the on-axis (Hor 0) scan (but don't apply any changes yet).
- Without moving anything, grab a sweep from the DXT and get an estimated IR delay. Because the driver is delay corresponds to the hypotenuse of the triangle formed by the on-axis distance to the DXT and the driver separation. Calculate what the on-axis delay would be.
- Move to the DXT axis, making a best effort to replicate the distance. Take a scan and get an estimated IR delay, which should match the prediction from step 2. Adjust and repeat as necessary.
- Set up on the Purifi axis for the vertical data. Adjust as needed to replicate the IR delay from step 1.
- Set up on the DXT axis for the vertical data. Adjust as needed to replicate the IR delay from step 3.
- Adjust all data using the DXT delay. Purifi data will have some remnant delay due to the depth of the driver.
This is a lot like what I did with the prototype. In that case, I separately corrected Purify and DXT data for microphone distance, then applied an adjustment to just the Purifi (or just the DXT) corresponding to the IR delay difference between the two.
Any better ways??? I've read kimmosoto's guide over and over and there is no mention of maintaining timing when re-aligning the microphone with driver axes. 10 degrees in the upper part of the crossover region is just a couple of mm.
