For me, the new Dirac Live app isn't working at all anymore. It says it cannot connect to the servers.
If the new feature is used to generate a target curve it should be independent from the method of filter implementation, i guess?Is the new algorithm mentioned available in the plugin? I'm still hesitant to give up using SoundSource and having it host the plugin. It's such a handy little app.
Yesss... my bad, I meant ceiling, thanksFloor? The link doesn't explain how that could be beneficial. Or do you mean ceiling?
I was also confused and spent some time wondering if it had anything to do with undirected floor reflections being more likely to reach our ears (since most speakers are closer to the floor than the ceiling and the angles would be wider and more likely to strike our ears on the first reflection rather than ceiling reflections which might bounce twice before reaching us. Or if the acoustically cluttered floor with tables, rugs, etc was more important to model than the typical 'plane' of a ceilings).Yesss... my bad, I meant ceiling, thanks
(I've corrected my previous post)
Got the link to update to 3.3.0 this morning. Will contact NAD about the cal file for the T758v3 give-away mic.Great news leading to two questions: (1) I'm running 3.2.2 with my NAD T758v3 AVR running and logged in, but don't see a prompt to l update to 3.3.0 (2) I dropped mu UMIK-1 and have to use the hockey puck mic that came with the AVR, but can't seem to locate the cal file on the NAD website or in any directory of the PC. I'm assuming it is a .txt file.
Does the new algorithm require us to re-measure, or re-load the filter at all? I'm currently using a filter with no manual target curve adjustments.
Thanks for sharing the news!
read on their facebook page a response on a comment, and they said no you could apply it on the older measurements!Came here to post the same thing. Do I need to remeasure or can I load an old project and just regenerate the filter?
DLBC? It has been available for a while but still evolving.
It still eludes me how this could take you so long? DLBS at the start called "New Bass Management Module" has been kicking around since late 2018.Exactly, evolving... but not available to the public
The preview version that you have is a testing version and non-complete but we expect that Dirac Bass Control for our own Processor for PC/Mac will be available during the last quarter of this year
Even before that, Dirac stated clearly that development of the Processor for PC/Mac would take a back seat to the embedded versions. Perhaps we should imagine a bus rather than a sedan.We are talking about basically a new feature to an already established suite from a big player, are really necessary +3 years of development and testing to intelligently correct the phase between independent channels and subwoofers?
I may know a little bit more than you think.You seem to not know what you're talking about. So here is a link describing the evolution in question.
The Arrival of Spatial Room Correction Technology - Dirac
This article describes an approach to the challenge of applying DSP room correction to complex multichannel setups, intended for immersive audio reproduction. Instead of one...www.dirac.com
They were supposed to announce it at CES2022 but then it got cancelled so it was the perfect opportunity to delay it some more.I may know a little bit more than you think.
This is what you have linked:
Ohh yeah November 2021...then pray to god its finished by 2025. And by the way, "Spatial Room Correction" is none other than the famous "Dirac Unison" project of 2016 or even earlier. Have a look of the very same graph from your link, but from 6 years ago...
Do they think that we, the users, are stupid? The internet never forgets. NEVER
They have been promising and hyping for years and underdelivering. That's a fact.
I don't want to get too conspiratorial, but I suspect that if they wanted to, you could have DLBC and Unison ready to go yesterday.
