Awesome! Peng, remind me, are you using Windows or Mac?I just ordered the Flex HT.
You can get quasi-balanced output with the right cables:Got it today, easy to use straight out of the box, no driver no nothing, just plug it in and it works like a multichannel dac as expected. I think because I used a 2x4 HD before so the drivers and other software were already installed prior. Very expensive for use with 2 channel stereo but I have no better option.
Wish it has balanced output but then cost would have to go up if they include that feature.
I am already using those, no noise concerns, just prefer 4 V for my Hypex amp that has only 25 dB gain. 2 V is enough for me, it is more a psychological thing.You can get quasi-balanced output with the right cables:
Same noise immunity as proper XLR Line out.
Will I get any benefits changing Cordial RCA to XLR cable (no issues) to Monoprice cable (ordered this morning) ?You can get quasi-balanced output with the right cables:
Nope.Will I get any benefits changing Cordial RCA to XLR cable (no issues) to Monoprice cable (ordered this morning) ?
If you have no issues currently, don't bother.While I'am using preamp in passive mode (variable output resistance) does it make any sense to add resistor in RCA ? Or should I switch to active mode and add 180 Ohm resistor to get it done better ?
Wdym? There is the Flex HTx for those that need it.I don't know why miniDSP still won't do better than this
I mean nowadays even a low cost AVRs preouts can do 4 V max on the unbalanced outputs, at a little lower SINAD, say around 60-70 dB would be my guess. The mini can do 2 V at better than 110 dB, if it can have the max at say, 3 V, at even 75 dB SINAD then it would be great. Anyway, I am not complaining, irs npt something I absolutely need.Wdym? There is the Flex HTx for those that need it.
Thanks, going to order mine now.Got it today, easy to use straight out of the box, no driver no nothing, just plug it in and it works like a multichannel dac as expected. I think because I used a 2x4 HD before so the drivers and other software were already installed prior. Very expensive for use with 2 channel stereo but I have no better option.
Any issues with setting up DLBC when you connected it? Did you use “custom config” or the 2.1?I mean nowadays even a low cost AVRs preouts can do 4 V max on the unbalanced outputs, at a little lower SINAD, say around 60-70 dB would be my guess. The mini can do 2 V at better than 110 dB, if it can have the max at say, 3 V, at even 75 dB SINAD then it would be great. Anyway, I am not complaining, irs npt something I absolutely need.
I don't think I am the only one who would not pay $500 more just to get 4 V, but for those who need the other additioning features the x offers, than yes the option is there.
I use custom stereo and just add 2 subwoofers, there wasn't any issues at all.Any issues with setting up DLBC when you connected it? Did you use “custom config” or the 2.1?
Congrat, the x is a great choice imo, if you do use the 8 channel analog inputs.Should be coming in soon!!
I wanted the combination of both balanced and unbalanced outputs. For $349 more I can always repurpose it down the line.Congrat, the x is a great choice imo, if you do use the 8 channel analog inputs.
Ooohhh me too. Very psyched to make sense of my crazy system with one box.I just ordered the Flex HT.
I only need 6 out. Is there any reason I can't use the last two analog outs for a headphone amp and use the HT for PEQ?
