RenPa
- Joined
- Dec 7, 2022
- Messages
- 137
- Likes
- 63
OK. Many of the comments in this thread implies new informations for me. For once, I didn't think that phase would be important for FR above 300Hz -issh. ( I am amateur and learned everything by myself on the net).All the 8 measurements above were done with Dirac Live correction on (not DLBC but regular Dirac Live)
So this means that I had to perform altogether 8 measurements to have one that is sort of OK-ish (the delay values for the rear channels were totally wrong, hence I am saying OK-ish)
Are you sure that 3.4.4 works fine for you?
I have tried that and although I do not get an exclamation mark issue the correction is still wrong, see post 42 here
I would perform some verification measurements with REW to see if it works fine
Second about Arcam issues above 3.4.4 version here are what I talk about:
- Calculated response does not match measured response in DLBC 3.9.7
- IRs between 3.4.4 and 3.9.7 are different enough to indicate either an issue or a change in how the optimization works
- Low-pass slope on the subs seems more like 12dB than 24dB (probably Arcam specific)
- In all versions of DLBC there is no IR plot of the corrected response displayed
Here unwrap phase of NO EQ Front left and 2 subs xo at 80Hz
Here the same with DLBC ON xo 80Hz
This is new for me but if I compare to yours, it seems DLBC optimization filter on helps phase isn't it?
