Dirac Live Exclamation Mark issue
Just a quick update, because I made some observations. ;)
The only change to my setup mentioned in the previous post:
-UMIK2 microphone, directly connected to my Mac Mini M4 (3 m USB-C cable)
Observations:
-two measurements on two different days: no problems :cool:
I'm seriously surprised that it worked without hickups. At the last measuring session I even caused a short disconnect of the UMIK2 - because I did bump the USB plug... :facepalm:
But I was able to continue the session without any problems, a short disconnect of the microphone (while moving it to the next position) seems to cause no issues at all for Dirac Live.
With a NAD M33, the combination of updating to Ver. 3.3.16 and using Uncle Manuel’s “unplug for 10 minutes” suggestion finally solved the problem for me. Thanks Unc!
I have an NAD M66 with the latest firmware 4.12.11 and was experiencing the same phase related imprecise measurement error. I saw the messages about unplugging for 10 minutes to fix. I didn't do exactly that but similar, I powered off my M66 flipped the off switch, then pulled the power cable out of the back, the flipped the unit back on while the power cable was unplugged which should drain the caps in the unit. I flipped the power switch a few times then plugged the power cable back in and turned it back on and the Dirac error message went away and i had no issues running about 20-30 different measurements.
I was using UMIK-1 connected via 6ft USB-C to a MacBook Pro running MacOS Sequoia and Dirac 3.14.1
