Hey guys,
I’m working on integrating my 2.1 setup and want to verify if my proposed workflow makes sense technically, or if I’m missing a glaring issue with phase or timing.
My gear:
- Source/DSP: PC running Equalizer APO\WiiM Ultra
- Power Amp: Audiophonics AP300-S250NC
- Speakers: AsciLab C6B
- Subwoofer: Arendal 1723 1S
- Measurement: Dayton iMM-6C
Instead of doing everything inside a single software ecosystem, I want to split the workload to let each piece of hardware/software do what it does best.
Here is the exact step by step approach I'm planning to take:
Step 1: Establish the Hardware Routing & Crossover
Before running any software calibration, I activate the crossover network so the software sees the system exactly how it will play music.
- Enable the Subwoofer output in the WiiM Ultra app.
- Set the crossover point to 80 Hz using 24 dB/Oct Linkwitz-Riley slopes for both the mains and the sub.
- Result: The AsciLabs are now high-passed at 80 Hz, and the Arendal is low-passed at 80 Hz.
Step 2: Measure and EQ the Subwoofer Individually (REW)
I want to clean up the brutal sub-80 Hz room modes natively on the sub's hardware before the main calibration.
- Turn off the Audiophonics power amp so the AsciLab speakers are completely silent.
- Open REW and run measurement sweeps (20 Hz – 200 Hz) to capture just the subwoofer playing through the WiiM’s 80 Hz low-pass filter.
- Use REW’s EQ tool to target the room peaks below 80 Hz.
- Manually enter those generated Parametric EQ (PEQ) values directly into the Arendal App.
- Result: The subwoofer's native response is now flattened and tamed within the room.
Step 3: GSonic Reference
Now that the sub is pre-EQ'd and the hardware crossover is set, I treat the whole setup as a standard Left/Right stereo pair.
- Turn the Audiophonics power amp back on so both the speakers and the sub are live.
- Open the standalone GSonic Reference app on the PC.
- Run the spatial average measurement sweeps through the app using the Dayton mic. Because the WiiM crossover is already active, GSonic sees the acoustical summation of the mains and the pre-EQ'd sub working together.
- Let GSonic calculate the overall impulse response correction and phase alignment.
- Export the resulting stereo mixed-phase .wav convolution filter.
- Load the .wav file straight into the Equalizer APO engine on the PC.
My Logic:
By enabling the WiiM's 80 Hz crossover
first, I ensure GSonic isn't calibrating the AsciLabs full-range down to 40 Hz, which would completely break the calibration the moment the high-pass filter is applied later. Instead, GSonic fixes the final, combined response of the system.
Does this sequence hold up logically?
Appreciate any technical feedback or corrections.
