BetweenThePeaks
Hello everyone,
I am currently studying room calibration, room correction, and room treatment for a stereo music system.
I am a music lover trying to understand things step by step...
While reading and learning, I found myself in front of a kind of “wall”:
1. On one side, Dirac Live looks very effective and convenient, but for my situation the cost is very high, and I am not able (or willing) to spend that kind of money right now.
2. On the other side, the RAW approach (measure, understand the room, apply small manual corrections) is free and seems efficient, but it clearly requires more study, time, and learning.
At the moment, I am more inclined toward learning and using the RAW approach.
My idea is:
to use REW or other measurement tools installed on the small mini PC, always connected to power, running only measurement and correction software
keep corrections small and conservative (mainly cutting peaks, especially in bass).
While reading older threads, I also found references to an Android app called “Spectrum RTA”, developed by Leonid Arefev (Russian developer).
The app is no longer on the Play Store but can be found on APK repositories so I downloaded it.
Some users mentioned using it together with an external calibrated microphone, like the Dayton IMM-6 / IMM-6C ( that I already have) instead of the phone’s internal mic.
I am thinking of trying this setup:
Android phone + Spectrum RTA
Dayton IMM-6C with calibration file
mainly for peak detection, placement checks, and learning.
I know this is not a replacement for professional tools, but it looks like a low-cost, low-noise, practical way to learn, especially before investing money.
My question to the forum is:
What do you think is the best way to achieve meaningful audio improvement (especially bass control and overall balance) without spending a lot of money?
Is a RAW + manual correction approach realistic for a non expert?
Is using a mini PC always on a reasonable solution?
Are phone based measurements with an external mic acceptable for learning and basic correction?
What would you personally recommend as the best value / lowest cost path?
I’m here to learn so I will appreciate your suggestions.
I have WiiM Ultra with it's RoomFit, but as I could read it's not as efficient as above mentioned approaches.
Thank you.
My idea is:
Thank you.
