- Thread Starter
- #21
Uhhh not sure why nobody has yet mentioned the fact that SHD is now Roon endpoint.That would be a killer for me and NAD would be only choice.Why fret over Volumio if your going to use it daily with Roon?Am I wrong here?Also wondering if in fact SHD would be better in it's xover functions and Dirac or is that not the case i.e. NAD full Dirac license will allow for same level of funtion all be it without 2/4 out (essential for me if I think at some point I might want to use it as full crossover).But to me Roon puts SHD in lead at the finish line.Thoughts corrections?
Isn't the NAD also a Roon endpoint? I don't use Roon.
I believe SHD has more flexible crossover functions. The NAD does allow you to select a crossover point up to 200Hz for its two subwoofer outputs, but the MiniDSP has more capabilities. See the SHD manual for details. That said, Dirac Bass Management may tip the scale the other way. We'll see.
I'm not sure if Dirac works differently on the MiniDSP compared to NAD. When I connected one subwoofer to the NAD and ran Dirac, it measured each of the three speakers separately (L, R, sub 1). I'm not sure it "sees" the subwoofer as a subwoofer, or if it's treated equally to the L/R outputs.
One thing I noticed on the NAD that confused me at first. The NAD has a menu option to select if you have no subs, 1 sub, or 2 subs, with a crossover activated in the latter two settings. Suppose I select no subs and then build a Dirac filter and export it to the NAD. If I then go into the menu and switch the subwoofer setting from no subs to 1 sub, the Dirac filter will silently override that setting and shut off the subwoofer and crossover even though from the NAD menu it appears the sub/crossover is active. The fact that this happens silently is confusing; ideally the NAD would "grey out" the subwoofer menu if Dirac is overriding it. But once I figured out what was going on, I like this function. Now I permanently leave the subwoofer setting active (1 sub, with my desired crossover), and if I want to toggle sub on/off I do it all with the Dirac filter selection. In other words, I switch between "no sub + Dirac filter #1" and "sub + Dirac filter #2" with a single menu setting (the Dirac filter selection), rather than needing to switch both the Dirac filter and the subwoofer settings in tandem.
