Dirac Live/Bass Control Target Curve Confusion
Azagoth
Hello all. Im not sure where to post this and I couldn't find my specific question. I recently got an Arcam AV41/PA720 combo that came with Dirac Live and then I bought Bass Control. I can run the measurements and set the Target Curves fine. My confusion comes with where to load the Target Curves. Under Dirac live you can load them but then when I go to Bass Control you can load them again. I thought that it would be for the Bass control group but you can load Target Curves for all groups again. If I go back to the Dirac Live tab then the Target Curve is back to default and I have to reload a Target Curve. Then if I go back to Bass control its different again. Im new to Dirac and its pretty straight forward but this part confuses me. Where am I supposed to load the Target Curve? Do I load it twice? Any help or advice would be appreciated. Thank you
Load them into which mode of Dirac you use to generate the output filters.
