Better not hold your breath then, I can't see it coming based on reading the comments from Dirac above. Notwithstanding the fact NAD are the worst for not living up to the promise MDC offers in upgrade terms, but technically it appears confirmed in this thread you need a multi-channel DAC for DLBC. The C658 (including the other current Dirac models M33, M10, C399) is only a 2ch DAC internally which just splits the L/R signal with a common high/low pass between main and sub outputs.I'm still waiting for the DLBC upgrade to the NAD C658.
I stopped holding my breath a while ago. Even for such a basic feature as a volume limiter for the C658 to stop my speakers exploding by a finger slip.Better not hold your breath then
Hadn't realised you can't do volume limits - that's a big no-no for me for then with digital/app controlled volumes. Like you say, a finger slip away from destroying your speakers!I stopped holding my breath a while ago. Even for such a basic feature as a volume limiter for the C658 to stop my speakers exploding by a finger slip.
Yup, sure would! We're so close to the 'perfect' product with a few manufactures too, but alas they all fall short just somewhere. By my definition of perfect I mean a highly resolving/measuring, singular integrated box that can act as both analogue and digital pre, with proper room correction including subs, plus a nice streaming capability (other than Roon!).A streamer like the C658 with DLBC would be so nice to have.
Very unlikely. I’ll get a 4 channel interface instead of the Flex for that reasonDo we think this could be used with a mini DSP flex?
It's possible, they just need to write a new software for it.Very unlikely. I’ll get a 4 channel interface instead of the Flex for that reason
What interface are you thinking of with similar or better performance?Very unlikely. I’ll get a 4 channel interface instead of the Flex for that reason
isn't flex a 2X4 ?Very unlikely. I’ll get a 4 channel interface instead of the Flex for that reason
Yepisn't flex a 2X4 ?
so flex is a possible candidate for the upgrade ?
Focusrite Clarett +2 Pre looks interesting because the front knob is able to control all 4 outputs. It also has a toslink input.What interface are you thinking of with similar or better performance?
I run Dirac off my main PC for my HT/gaming/music system and it works great. Infinite flexibility inside software environment. I've used on-board audio, dedicated sound-cards, and external USB sound-cards all to great success. Xonar U5 (6 channel) and U7 (8 channel) available for $100 or less. Creative has their X3 (now X4) comparative.Do you think a 4 Channel interface+ Intel NUC running Dirac would be a viable alternative to the Flex if it won't support DLBC?
It still lacks a 'hardware' remote but Windows volume should be fine too (and can be remote controlled with a Flirc)
Sort of - this will be a paradigm shift.. the next step up after DLBCIf by any chance is related to the subject under discussion:
This means that the low frequency capabilities of ALL speakers are integrated as a single whole.... It will make having full range speakers for your surrounds a worthwhile proposition.
That can drastically change how certain speakers are designed. Full Rangel center speakers do exist, but height...Sort of - this will be a paradigm shift.. the next step up after DLBC
Height will still be more limited, but it can use the range up to 500Hz, so there is plenty of scope there...That can drastically change how certain speakers are designed. Full Rangel center speakers do exist, but height...
