That is much better. Here is a comparison of the waterfall of your previous measurement (left) and your current (right):
View attachment 563502View attachment 563504
I have left them both at the same scale. This time you have increased the SPL of your measurement by 10dB, and you have done a 1M sweep (old measurement was a 256k sweep). You can see what effect this has had on the noise floor - it has pushed it down considerably.
However, your new measurement does have an issue. Look at that decay at 47Hz (circled) in your new measurement, and how it is about -3dB to the signal. Also notice how it's not as loud in your previous measurement. If you look at your spectrogram, you will see:
... this ugly area of decay.
I am pretty convinced that it is extraneous noise, despite you being able to successfully suppress the noise floor. Noise that loud (-3dB!) at 50Hz should be VERY audible. Given that it has occurred at the same frequency, and it has become louder with increasing SPL, I have to ask you whether you think there is some kind of furniture / floor / window rattling at that frequency.
If you want to confirm this, take 3 measurements at the same SPL and at 1M length back to back and compare the waterfall. Listen carefully for some kind of resonance. If you don't hear one, ask yourself if your microphone stand is resonating and transmitting noise to the microphone. You could also use REW's generator to play a 50Hz tone, and then walk around your room listening for where it came from. If you touch it, it should stop.
Sometimes, 50Hz noise can be a ground loop. But this looks a bit too broad to be a ground loop, those tend to look very narrow. And ground loops do not decay, they form straight lines like a flat sheet on the waterfall, or straight lines on the spectrogram. Which is why I think it's some kind of furniture resonance.
If we ignore that area of decay, the decay on both spectro and waterfall look quite good. It looks like any other ART measurement I have seen, very impressive.
And no, your step response has not changed. This is a comparison of your current and old step response. It's exactly the same.
