Dirac ART Update
Please see REW Book 2 (link in my signature) for examples of an ideal step response. You can simulate it yourself. Using REW's "EQ" feature, create a bandpass filter. HPF 20Hz, Butterworth 4th order, and LPF 20kHz, Butterworth 4th order. That simulates an ideal minimum-phase speaker with a spectrum of 20Hz - 20kHz. Then go and examine all the graphs, including the step response.
(EDIT) I have created that ideal step response (in black). Here it is in comparison to the OP's measurement.
I am not a MIMO expert at all but everything I have read about MIMO in regards to impulse and step responses is that it aims have the "best" (which is pre-defined in the algorithm and may contain psychoacoustic allowances / compromises) impulse and step response at the LP but that every step and impulse response from any individual speaker is going to be "wrong" and "different" than what you would expect / want from a SISO system. The goal is to optimise the step and impulse from a summed response at the LP. To me it seems like trying to "analyse" or "optimise" DIRAC ART using a SISO perspective is not really valid. Since ART is a "black box" you can't really even compare what it is doing to what it is trying to do. About all you can do is look at it and confirm "sanity" (I have had measurements where ART created 120 ms delays where 2 ms were appropriate) and see what it is doing and hope they know what they are doing and that is "sounds good".
It is NOT a "SISO perspective", it is a psychoacoustics perspective. The question is whether that amount of "pre-ring" is audible, and if it is audible, it is bad.
When Floyd Toole was asked what he thought of the GedLee distortion metric (where distortion products are weighted according to their probability of audibility) his response was, "the only objective metric for distortion to be inaudible is zero". I have the same view with pre-ring, the only objective metric which guarantees inaudibility of pre-ring is zero. I am not that much of a purist though, and I will not insist that all pre-ring is bad. My view is that I would rather not see it, than to see it and question if it is audible. If it falls under psychoacoustic thresholds, and if you can't hear it ... for me, it will get a pass. To me, all those ASR members who aren't complaining of pre-ring has some weight.
The real question is what did ART "trade" for the pre-ringing (maybe their famous decay improvement or the extra smooth FR response below 150 Hz ?) and how audible an improvement is it compared how negatively audible is the pre-ringing? Since ART is a black box we will never know for sure but I think it is difficult to look at individual elements of an ART measurement and draw any conclusions. At some point you have to listen and decide if you like what ART is doing or not.
I've now listened to the recommended Japanese Drums and JazzNova tracks.
I hear no 'pre-ringing' with Dirac ON. If I turn Dirac OFF, then the drum sound is horribly smeared, due to uneven frequency response and awful 'post-ring'. A typical case of listening to the room!
These indeed are now my two references for accurate bass reproduction. I almost fell of my couch seat when I heard those first Japanese drum beats.
I think that Dirac's sound improvements can be measured by REW, for example by comparing its 'waterfall' or 'spectrum' analyses. I don't know what to say about what the 'impulse response' comparison may or may not reveal.
God only knows, it looks like!
Anyway thanks for to all for this discussion.
I guess that all measurements presented here are taken at MLP. But I wonder, how does ART work at wider area. What is the difference if we measure at 2-3m from MLP?
Interesting question.
We should also discuss the results of all other "room correction" systems using phase linearization (linear phase filters with inherent pre-ringing) at other positions than the MLP.
Yes, the was MLP, in Dolby. So the center channel is heavily involved. But that's a good question, what happens a meter or two on either side. Supposedly, this would reveal a major strength of Dirac in the bass domain, especially with four subwoofers individually filtered and surrounding the listener (does this last one matter??)?
At some precise distance from the MLB, there should be no pre-ringing issue, correct? What is that distance, I'm going to measure again tomorrow...
I have that measurement.
Here are 3 step responses: at MLP (red), 2m to the left of MLP (blue) and 2m to the right (yellow). You can see that the pre-ring is worst in the blue measurement.
While some spots in the room are going to be better and worse my understand is that the only way to mostly cancel pre-ringing if you use linear phase crossover filters is to have the drivers spaced 1/4 wavelength or less of the crossover frequency away from each other so they act as a point source and the filters themselves are "complimentary" (same slope and frequency) and perfectly time aligned and preferably on the same baffle with both drivers operating in a range that is linear for them at the crossover frequency. Even then the cancellation is imperfect and will vary based on position in the room but it can be very low and inaudible. This is difficult to achieve unless using well designed full range speakers or possibly co-located subs, and won't be possible with multiple distributed subs. This is why DIRAC ART uses "mixed" filters which will hopefully creates an optimized result by balancing all the trade offs.
By the way, here's what Google AI says about my Dirac-induced 'pre-ringing'...
Knowing that the system is running Dirac Live Active Room Treatment (ART), this completely recontextualizes the measurement.
What REW is showing in the step response is not traditional linear-phase digital pre-ringing. Instead, it is a well-documented physical characteristic of how Dirac ART works: it is actively firing your subwoofers (or supporting speakers) early.
I have seen this reported as well but as far as I know it is just speculation as DIRAC has not disclosed a lot of details about the inner workings of ART.
That's what I said a few days ago. And if I said it, you have to suspect that Google's AI mined ASR for the answer.
Don't listen to that bloody AI. I once asked it a question for which I was uncertain about the answer. It gave me a confident sounding answer. When I checked its sources, its primary source was a post I made on ASR.
I still believe I am correct, though. But the only way to confirm that for yourself is to do the measurement I suggested. You need a measurement of each individual speaker in your system with a timing reference, and a measurement of all the speakers together (let's call this "ALL"). Then using REW's "Overlays", display the step response for "ALL". Click/unclick each individual speaker, and you will see where their peaks line up in the step response. You can see the shape of the individual subwoofer measurement, and you will see that it is firing early.
If you want, you could even compare the shape of the step response of the subwoofer with and without DSP. You could try to model the subwoofer in REW and understand why the step response looks the way it does. You have a microphone, you have curiosity ... you can have endless hours of fun :D
When I saw the AI post I thought of you as I know you have mentioned the early sub firing in several posts on ASR. Do you have any idea why they are doing that? Seems like it might have something to do with the cancelling of decay but I am not sure how that would work. DIRAC has done some work both on what sounds good and what looks good on graphs. I wish they would share their findings but that would not make sense for a commercial company selling a black box. I do subjectively find ART to sound very good, especially the bass which then cleans up the mid-range. For an automatic product I think it does well as long as you play by the rules on taking the initial measurements.
Simple answer: they know something that I don't. Those are very talented people with Ph.D's who get paid a lot of money. I am an amateur on his home PC with a doctorate in something else.
I might be interested to try to test. Winter is coming so I will have time.
I have measurement for each speaker with and without Art. With Art though, it is with the 2 subs playing.
I don't know how to measure ALL 5 satellites speakers together in REW.
The pre-ringing seen on REW's step graph is simply the support speaker firing earlier, it is inaudible as a pre-echo because the part before t=0 belongs to another speaker. A MIMO algo needs to work with a look ahead buffer to keep things causal.
Re: measuring all 5 satellite speakers together. That's not REW's problem, that's your AVR's problem. You have to figure out how to send REW's L+R signal to all your speakers. Consult your AVR's manual.
Re: measuring subwoofers individually. Turn off one subwoofer or disconnect it, then measure the remaining subwoofer. In the same way, it is possible to measure each individual speaker, once you figure out how to send signal to all the speakers. You simply disconnect all the speakers except the one you are measuring, and the one you are using as an acoustic reference. This is why I love my RME interface, I can simply mute any channel I like without having to get out of my chair :)
Yes, this is an END to the question of why Dirac ART imposes a 'pre-ring' as measured by REW, I think.
Since ART doesn't have a crossover in the traditional sense (it is MIMO) what type of crossover would you be using for the "Without Art" measurement?
