Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Welcome to ASR. There are many reviews of audio hardware and expert members to help answer your questions.
Click here to have your audio equipment measured for free!
For whatever its worth ive had better luck getting UMAMI PREFECT SOUP working, wish I could A and B them, given I cant figure DIRAC ART out yet , but they are supposed to more or less do the same type of correction.
I've downloaded Dirac on my Windows machine and received the trial version key. However the app does not recognize the license despite it being activated. I've contacted Dirac and received no answer despite it being over a week.
Even if you limit frequency correction to 200 Hz, the timing correction will still be done, so I would not expect the phantom center to change. If you turn the "delay" and "gain" buttons of, does this change anything significantly?
Finally got around to trying this and yes turning off the "delay compensation" snaps the phantom center back into focus. Looking at the delays added they are mostly 0 with a few 0.3 ms and 0.6 ms delays, based on geometry I would expect them all to be very close to 0. Does that mean I need to remeasure and if so what would I do differently so it works correctly? DIRAC can't possibly expect all the measurement positions to be "perfect" (within an inch or less) but maybe the first measurement has to be as mentioned previously?
The first measurement should be perfect. The rest need to be at least 12” from that one and each other and no more than 24” from another measurement, that last part shouldn’t matter for you. Just do the 9 close option and take them out roughly a foot but don’t be short. I do 6” above MLP (1st measure) and 6” below for the 8 in a square if you are following the instructions. After the first measurement you can do it however you want, I just follow the instructions. I also add 9 more but you don’t have to do that if you don’t want. I’ve never back to back compared 9 vs.18. The spread graphic gets wider with more measurements, which makes sense.
I can't think of any good reason to turn "Delay Compensation" off.
But if you do, disable the option in both the Standalone\Plugin and the Dirac Live software and then recalculate the filters.
Try to do the first measurement perfectly symetrical between left and right. You can take look a with the "Impulse Response" button in the filter design, and see if the curves for left and right speaker are as close as possible on top of each other. If not, adjust and redo the first measurement
Maybe there is some reflection that makes Dirac think the delay of each speaker is not where it acually is. In that case, repositioning or even treatment of reflection points may be the way to go, though I know thats not allways feasible.
Spent the time to remeasure making sure the first measurement was "perfect" (within 1/8") and the impulse responses landed on top of each other. Unfortunately the filters generated are even worse than before with ART adding a 1.5 ms delay to the left channel even though the MIC was perfectly centered. This creates a terrible phantom center which is very wide and sounds out of phase. Fortunately, due to issues I have had in the past with DLBC, I have the mains and 4 subs physically very close to time aligned with the LP (using a tape measure) so I can uncheck the delay compensation and the phantom center snaps back into focus and then the bass and EQ ART does sounds very good. Unfortunately this makes me wonder what else is going wrong with the black box algorithm and makes me hesitant to use ART.
That is indeed strange, but very difficult do say from the outside what goes wrong. I am unsure if unchecking delay compensation is the way to go, since ART relies on delayed compensation signals from the support speakers. But I don't have enough knowledge of the inner workings of ART to say that with certainty
I tried one last thing which was digging out an old UMIK-1 MIC and took measurements with it instead of an Earthworks M23 and an interface. I read somewhere that DIRAC was optimised for the UMIK-1 which doesn't make a lot of sense but for whatever reason even though the measurements didn't look any different they generated completely different delays which actually make sense based on the physical location of the speakers and the phantom center sounds as it should. I need to spend some time listening and measuring to make sure it is working correctly but so far so good.
Interesting, I have no experience using Mics with Interface for Dirac, but it should work, if you do everything right
Personally I use the Umik-2 and have allways had very good and consistent results with it.
