Dirac ART on Mac and PC
I did not find it made a big difference in a small-room nearfield setup compared with Gelelec GLM and one subwoofer.
That's what I thought, for my desktop system, even the simple DL works well and DLBC works really well, and the LS50's response there dropped a lot at >100 Hz though it picked up strongly at around 35 Hz all the way to almost 20 Hz, so I think it would not help very much.
By the way, I saw many posts that show there were manual adjustments post ART, on this PC based version I don't see any such manual adjustment options.
I don't think ART has ever allowed that although many want it. It definitely doesn't work on the TIDE16.
I finally started the 14 day trial a few days ago. Unfortunately I assume the trial license, like the regular license would allow me to use it on two PCs so for convenience I started with my desktop system that includes left/right LS50 and one small sub. So far, I find it hard to hear a difference, ART did reduce the deep bass by 2-3 dB and fixed a sharp dip at 90 Hz but not enough to make an obvious difference audibly.
Anyway, since I can't try it on my BMR bookshelves+2 SB1000Pro, I am not going to buy it at full price, in case it wouldn't make much difference there either.
I too find a much bigger difference in my living room 7.3. system than in my office 2.1. That's not surprising considering the different capabilities of the systems and how ART works.
Maybe you can switch the local IP-adresses of your PCs, to use ART on your other system for a test?
I can try, so you think Dirac checks which, and how many PCs are using it by checking the IP address? I thought they might be going with something more sure, such as something that sticks with the hardware itself, such as mac address.
But the owners of the AV10 have posted their graphs showing the % support and frequency that seemed changeable, but that may just be my assumption, guys like @Oddball can confirm that..
But the owners of the AV10 has posted their graphs showing the % support and frequency that seemed changeable, but that may just be my assumption, guys like @Oddball can confirm that..
Click on the 3 dots under the group to bring this window up.
You can type over any of those parameters. Support level isn’t a %, nor is it really db but that’s how it is labeled. F support high and low are the parameters for where you want your support speakers to operate. You can also click on and move the sliders in the lower left of the screen to make some of the same adjustments. Beside those sliders to the left is a check box for the infra bass as well.
Is this what you were looking for?
Thank you very much.
I don't think frequency is changeable, just support. It's not really what I would call 'manual adjustments post-ART'.
It doesn't do anything meaningful like PEQ or absolute db levels.
That was my impression that it is IP connected, but I might very well be wrong. When I switched my old PC for a Mac I had to contact Dirac to reset the license, I assumed because the new computer had a different IP adress.
Yes, I was talking about the support frequencies, and thanks to JRowland, I was able to tweak the F-support low a little, from 50 Hz to 110 Hz.
ART for some reason, expect my tiny LS50 can support down to 50 Hz, that, based on the REW graphs actually might have made things worse so I changed it to 110 Hz and it looked better now. For group 2, that is the subwoofer, I leave the frequencies unchanged but changed Support level from -18 dB to -16 dB.
Spectrogram with ART:
With DL filters disabled:
Response quite flat up to 300 Hz, it doesn't look that flat in the deep bass because of the added bass tilt. The dip around 150 Hz can be fixed easily but I am going to leave that alone.
Response quite flat up to 300 Hz, it does look that flat in the deep bass because of the added bass tilt. The dip around 150 Hz can be fixed easily but I am going to leave that alone.
Looks good! If both L/R speakers present similar graphs leaving them grouped is fine. If they are different (I have one near a corner and my other is midwall kind of) you can put your mouse on one of the speakers in the group and just drag it off to the side and it will make another group. You will have to update your FS settings again but it is something else you can play around with if needed.
Well they are a pair of LS50 used on my desktop and they do present similar graphs, not the same but similar enough. I do appreciate Dirac allows some manual intervention, there is no way those little LS50 can support the sub, albeit a small sub but dig very deep sitting under the desk Lol. That little does seem contributing to better clarity, supporting the speaker group. Just too bad I did not activate the trial license on my laptop that is used one floor below for the Philharmonic BMR+two subs, surely ART would make more of a difference there. I could still try it on my pair of tower speakers in the next room, served by the same desktop PC, but there I don't have any sub to support the towers. Wonder if ART would make an audible difference for just a pair of towers without subs.
I’m curious about that as well, I haven’t seen a report on that yet if you get the itch. I would think you would enjoy ART with your BMR sub combo if and when.
I was wrong, REW graphs confirmed that the only way I can get outputs 3 and 4 from my miniDSP Flex HTx, used as a 4 channel DAC is if I left things alone after clicking "Calculate" to run BC. If I regrouped them after finishing running BC, such that sub 1 is with the left speaker and sub 2 with the right speaker and then export the filters, I would not get outputs from channel 3 and 4.
That means when BC is used, there is no point tweaking the left and right target curves, and/or subwoofer target curves separately because it would not work right. Still haven't try ART yet, and that may make a difference as I can't imagine how ART work if the speakers and subwoofers are not in separate group.
When grouped as shown in the scr shot on the left (default after running bass control) will output bass to sub1 and sub2. If grouped as shown the the scr shot on the right, there would be no output to channel 3,4, i.e. sub1 and sub21. If re-run bass control again, the grouping would automatically revert back to as shown in the left screenshot.
View attachment 547056View attachment 547057
Hi! Did you try this again with ART and see if if works? I'm thinking of getting a Flex HT to do the same thing you're trying to do (as there is a dearth of multichannel dacs under 1000 USD available) with Dirac ART on my Mac Mini server.
Scarlet and Motu have many interfaces under $1,000. I messed around trying to avoid buying a multi channel DAC and it was a waste of time if you are going to have a PC based system. I have a Motu ultralite Mk5 which has plenty of channels and an ADC and a ton of features for way under $1,000. One of the most satisfing HI-FI purchases I have made.
The trial license works on one PC only, I mistakenly had it activated on my 2.1 so I can't test it on my 2.2 system now, unless I buy the license.
On the 2.1 system, I tried separating the left right channel and am able to have it set up as 3 groups with ART. So now I know it would work with ART but not with BC. I think Dirac knows what's best so I am okay with the way it is.
I use a Motu M4 and it's great. Thing is, that I'd really like to use a remote control, and have a knob, mostly for the sake of the rest of the family. I've tried different bluetooth knobs but I haven't been able to use it on my mac mini server. It's mainly ease of use.
I have not tried it but the Ultralite MK5 had gained some remote control ability with a firmware update https://www.soundonsound.com/news/motu-ultralite-mk5-gains-wi-fi-access-control-room-features
I thought I saw a 3rd party solution based on the Wi-Fi connections but can't find it now.
Me too I'm using a motu ultralite mk5. Great product.
I confirm that, if you connect it to a pc/mac connected to your wifi, any other pc/mac/ipad also connected to the same wifi can remote control the interface through the cuemix 5 app. Very handy and you can also change the master volume.
It doesn't work with android (but I readed some has found workaround for that too, you should easily find more info).
Personally I have dirac on a mac mini headless connected to the motu and I control volume with a fosi vol20 (works great for volume, play/stop or skip track and it's easy for me) or via screensharing from a mac air
How did you manage to use the Vol20? I tried but I couldn't do it, so I sold it!
