Thanks for sharingJust saw the livestream on room treatments from Phil J. and in it he says dirac art will come in a couple of months. So I'm not counting on sep, maybe not even October?
Kinda, sorta happy? More time to decide on the fourth subwoofer. I shoud have known when I got the 3800 how it would end up. I had a single sub before...Just saw the livestream on room treatments from Phil J. and in it he says dirac art will come in a couple of months. So I'm not counting on sep, maybe not even October?
Ok, so from a single subwoofer you went to 2 sw? And that was a big step up? In what way? And you wanted more so 3?Kinda, sorta happy? More time to decide on the fourth subwoofer. I shoud have known when I got the 3800 how it would end up. I had a single sub before...![]()
I went to 2 when DLBC became available, then I went to 3. In both cases bass response was better than before (measured in REW).Ok, so from a single subwoofer you went to 2 sw? And that was a big step up? In what way? And you wanted more so 3?
I don't think there is precise definition as both are relatively loose terms. I would expect it by YE though.After coming home after work I watched part of the video and Phil said "next few months". From 35:00
How can you interpret this vs couple of months?
No he said all models with 4 subwoofer outputs will get ART so it will be a simultaneous release.I don't think there is precise definition as both are relatively loose terms. I would expect it by YE though.
Did Phil or anyone hint to a possibility of rolling out gradually across the line-up? Not exactly the most fair method, but could help with them being able to handle a larger number of support requests that might / could be reasonably expected to come.
Cedia 2025 seems an obvious occasion and venue for a launch of this kind, next big event is CES in January, which I think is too late...I don't think there is precise definition as both are relatively loose terms. I would expect it by YE though.
And a third SVS SB-1000 is on the way (the fourth sub is a SB2000).More time to decide on the fourth subwoofer.
Hahaha, nice that you bought the 4rth one!I went to 2 when DLBC became available, then I went to 3. In both cases bass response was better than before (measured in REW).
All sound quality impressions (and measurements) taken at MLP. I have a three seats set-up but, at the end of the day, I have decided to completely disregard whatever happens at my sides. I'm the only one who cares and those two seats are anyway used quite rarely.Hahaha, nice that you bought the 4rth one!
Ok, response in REW better, but did the bass in the MPL also improve? Or is the added value more in other seats?
I have a good response in the MLP and always sit there. My wife and little on the side but she doesn't even know what a subwoofer is. So would adding say a second 13.8 inch arendal 1s sub really yield some noticeable improvements in de MPL for me?
Cool, thanks. I'm first going to try ART and see if I'm happy with thatAll sound quality impressions (and measurements) taken at MLP. I have a three seats set-up but, at the end of the day, I have decided to completely disregard whatever happens at my sides. I'm the only one who cares and those two seats are anyway used quite rarely.
For me the improvements were perceptible and measurable but, as usual, your mileage may vary. And, in this case, it really could, as there are so many variables involved.
When I added 4th subwoofer to my Marantz AV-10, disaster followed: very weak and very uneven bass after calibration with DLBC. I tried several times, read that some people experienced the same, gave up, removed one subwoofer and things got back to normal. I hope the ART update will fix it.Hahaha, nice that you bought the 4rth one!
Holy hell! Talk about making me afraid!When I added 4th subwoofer to my Marantz AV-10, disaster followed: very weak and very uneven bass after calibration with DLBC. I tried several times, read that some people experienced the same, gave up, removed one subwoofer and things got back to normal. I hope the ART update will fix it.
