Dirac ART for 2-Channel Stereo Music
I recently had massive delay errors and the solution was to move the 2 support subs closer to the LP. My listening distance from the mains is 6.5 ft with colocated subs. When I added 2 support subs ~11 ft from LP ART went haywire setting over 100 ms delays. I moved support sub ~ 7 ft from LP, remeasured, and eveything started working. Reading online it is a common issue apparently.
Interesting, my subs are at relatively even distance - 3 and 3.5m. But you made a good point, I'm going to move sub and see what happens. I already tried to move it around half a meter, but it didn't make any difference.
I believe so. They basically resell all Dirac licenses with discount. Simply fill the form to request a quote https://www.audiowizard.co.uk/buy-dirac
Well, thank you. almost 45$ saved.
My wife listened to 2 systems, and said the following (Im compressing it to the meaning): "for me these two filters sounds both great, the new one (ART) is more forward in bass, but for me it is not better or worse, it is different".
Basically in a sense DLBC is good enough for non trained listener. I agree with the point, both are great, but ART for me last 10-5% in bass region that makes it click and almost perfect for me.
If you have DLBC, you already in good place, ART is closer to final step on the ladder.
Are your main speakers full range?
Ok, So I got another audio interface and re-installed MacOs. I still have issues with delays, but looks like only when I start Dirac calibration from reaper. If I do it directly I'm getting normal delays (within 5ms).
So not sure what's changed and what's the problem with reaper. I suspect some sample rate settings somewhere causing it etc, but I can't figure out where.
I also noticed that when listening to music I sometimes getting pops and clicks like on a vinyl, so there is somewhere clock drift or something. CPU is very low (<10%) while Dirac is running, so maybe coax cable to KEF wirelss2 is the issue
There is a huge difference between DLBC and ART in my case and ART is significantly better, although I had to raise low fq to max +12db to make it to my liking...
Chiming in for a reference.
Just got trial version, and got my old measurements for 2+2 system.
I think most value out of ART is that subs + crossover now works much better, bass it very tight, and it makes midrage to openup a bit in scene (I cant explain, but that control over bass gives a space for midrange to be more textured and focused).
Running Neumann monitors + 2 subs for it.
So for me key diffirence in clear controlled tight bass via integration of mains with subs and midrage that is oppening up due to cleaning up bass region (might be attention/awareness thing).
I will use it for a couple weeks, but I already know that I will buy it. Running on Mac OS (Mac Mini M4).
p.s. oh man that bass. Like in planar headphones but in room.
Chiming in with upgrade. I made my main system to 5.2 with that setup.
  • MiniDSP Tide16 Processor, Dirac Live ART included
  • Kef R11 mains
  • Monolith 12 V2 subs
  • Center and 2 Surrounds Kali LP6 V2 active monitors (via XLR)
3 support groups:
  • center
  • surrounds
  • 2subs (I did not separated them, will experiment later, but I doubt that it will make any difference)
center+surrounds indeed playing and supporting the mains, I can hear it if put my ear near, and I can see it on output level on Processor for each channel.
Is it day and night compared to my previouse setup (Mac + DM7 and 4 channels)? No. But I think there is difference, I did not do AB, so I cant be objective, to be fair, the sound is fantastic. I never thought it can sound as such in my current room.
Tide 16 is a great processor.
p.s. I do not do upmixing with Dolby or DTS, in stereo mode I got the most quality per my taste.
Forgive me if this is off-topic, but Is buying an AVR, such as the Denon X3800H, the easiest way to get Dirac ART in a 2.2 system intended to play mostly music? I'm looking for the quickest path to upgrade my 2.1 stereo system (I use DLBC w/ NAD C658) to 2.2 with ART. I would like to stay away from computer based solutions because I prefer a traditional remote/couch based experience where all my sources (CD player, vinyl, etc) plug into my preamp.
short answer - yes it is the easiest way
Denon X3800H or X3900H (newer model with so called better DAC) is a good way to start with Dirac ART. If you already have 2.1 speakers, you may keep the speakers and see how it goes with Dirac ART. If you have capable front left/right speakers, ART would use them as supporting speaker, and you probably don't need an additional subwoofer to form 2.2 system.
I also planned to get a second subwoofer last year before using ART, but it's no longer needed with ART for my case.
FYI, I (and some other members) bought my Dirac ART license with a discount from https://www.audiowizard.co.uk/
It depends, If you're ok with its amp quality etc - it is probably fine. Also you still need to pay substantial amount for ART upgrade.Also ART on denon and on storm audio or computer is not the same in terms of quality. Number of filters is significantly less. Also remember, on denon, it stays with the device, where if you buy it - you can use it forever with anything.
As for convenience with the remote - you can still use any preamp you want with digital output. Dirac is just a processor in a chain.
If the amps are not up to standard, turn them of and use the unit as pre-amp
That is the way i do with my C50 because i already have a fully active system - see the signature
But if I want Dirac ART applied to my turntable, SACD player, etc, I would need to plug everything into my computer right? Which means I need a sound card with several line-in inputs and then make room for this computer somewhere in my hifi rack? This just seems more complex to me (please correct me if I'm wrong), whereas with an ART compatible AVR, I can just plug all my sources into the AVR, like you do with any ordinary preamp.
For your use case i.e. multiple analog line level inputs, an ART compatible AVR is the simplest solution by far. For a use case where you just played files and or streamed from a streaming service then the computer solution becomes just as easy if not easier.
That makes sense!
Quick side question, when implementing a computer based ART solution, how does one connect the computer to amp and speakers? I assume you either need a sound card that has a minimum of 2.2 discrete channel outputs (assuming you want L + R + 2 subs). And in this case, aren't we right back to connecting these outputs to an AVR or similar situation?
Presumably you would go to subs, amps+passive or active monitors from there, no?
I am in a similar situation. Want to add 2 active subs to my active main speakers with Dirac ART to further improve bass quality.
I am using a RME ADI-2 Pro FS R ADC/DAC. When set to multichannel mode, I can run the input signal (stereo) via USB through my PC with jRiver Media Center and Dirac ART VST-plugin installed and receive Dirac ART processed four channel audio back via USB. AES/EBU digital goes to my mains, analog out goes to my two subs.
The RME unit has an input selector (2x digital, 1x analog in), volume control with adjustable loudness and bass/treble control.
You're relying on ADC quality in AVR, which is normally quite bad. I'm using wiim as a source and Mac mini just as a digital processor.
