Thank you but how do i get rew to not generate that signal and use that from roon?
mute your PC
I use my pc to generate that signal how To mute rew but not roon?mute your PC
because you’re streaming it to the hegel you’re not playing it on your PC.
just try it man before you complain
are you using var smoothing?
I don't know what in the world is going on but the left speaker looks WEIRD. like there are consistent ripples it's crazy, did you hear anything weird going on during the measurements?
Right is obviously much better but it's still a bit too messy, this is one of my measurments of my speakers in the living room (very reflective) with var smoothing. the speaker is measured by the NFS and is anechoicly flat
my advice is that you don't apply any EQ above 1KHz, (unless someone's EQ calculated off anechoic measurments).
did you make sure that both the file you play at Roon and the settings at Roon have matching sample rate? with the UMIK-1 you have to use 48KHz files.
I did use 48hz and only eqed up to 180hz
The left speaker is close to the wall and the right open to open plan.. maybe that is the cause?
Also the front wall is perfectly straight… is 4cm closer to the left speaker in comparison to the right
I'm not sure i haven't experienced that before.
Btw, feel free to do Speaker correction EQ first before doing measurements for room correction, the speaker is already very excellent and doesn't need much but it could give you slightly better results.
so try to remove all the EQ you have set and follow the 'Score' EQ in this post. if you feel it makes the response worse of course feel free to not use it as well.
https://www.audiosciencereview.com/...-spinorama-and-measurements.18353/post-603589
After you have applied that EQ, do measurements from scratch and EQ up to 500Hz. don't add any boost.
lets see how it looks post speaker correction and post room correction.
btw you're using accoustic timing reference right?
EQ will only go so far, I would seriously consider room treatment! There are so really nice ones out there for not too much money!
https://www.gikacoustics.com/product-category/acoustic-art-panels/
https://www.gikacoustics.com/product/impression-2inch-acoustic-panel-diffusor-absorber/
https://www.audimute.com/soundproof...r-walls/acoustic-panels/acoustic-image-panels
https://www.acoustimac.com/acousticart
Hi George,
Is there any way to use Dirac or REW eq without Roon?
Audirvana don’t support?
I have Macbook and Lumin streamer.
I have no experience in this. There is no eq support in Lumin. How do i apply eq, i'm thinking about it.
you can use EqualizerAPO if you don't do any streaming and having your DAC directly connected to your PC.
My Benchmark dac2 connected to Lumin via optical toslink.
Lumin streams by itself.
Mac/pc is not in the current audio chain.
you have to check if Lumin itself offers any Room EQ options.
otherwise you have to put a device in the middle between the Lumin and the DAC such as the MiniDSP SHD studio.
Lumin don’t have Roon EQ options but it supports Roon Endpoint.
Can I EQ using Lumin as a Roon Endpoint? (With Dirac/REW)
