Is the front of your speakers (drivers) 1.2m from the front wall (wall behind the speakers)? That would explain the 70Hz null.from the graph it seems that where the graph deeps the Bass is thin.. so from my understanding that cannot Be fixed with room treatment ? if so how can I fix that? is it the speakers?
See these helpful guides from Genelec & Neumann. So the front wall seems to cause the ~90Hz dip.I will try to do the test aBout impulse albeit it seems rather complex lol.
the driver of my speakers is aBout 90cm - 1m from the front wall. what this has to do with thin Bass?
View attachment 124933View attachment 124934
It's certainly possible the 70Hz null can also be caused by a room mode in your listening position. You can add your room dimensions to REWs Room Sim to get clues what's behind the null.
Another, perhaps simpler way to approach the Impulse response is that the direct sound from the speaker hits the listening position/mic at 0ms and for every 1ms delay in time the sound has travelled 34cm longer. You'll get the hang of it! But again, this would be what I'd look at primarily if/when you get the absorption panels up on the back wall.
True, if you look at the Neumann guide with 'Bass managed loudspeakers' the only bad distances are 1m and 80cm since the SBIR null is close to the typical sub crossover area.it's very strange for them to say long distances are 'unacceptable' when they don't advertise their speakers to extend that low to begin with.
i would take that 2 meters distance and cross to a subwoofer instead.
Well, as you see on the RT60 graph your decay times at higher freqs are actually already quite good. You want to avoid thin absorption panels that absorb only treble and upper mids. Definitely add absorption on the back wall directly behind your listening position. If you want to add more elsewhere then something similar to GIKs diffusion/scattering plates (on top of broadband absorption panels) would be a good idea to keep some of the high freq energy 'alive' in the room. But again, since the back wall is so close to listening position, put 'pure' absorption (no diffusion/scattering) there.Thanks I will study it.
I will go with Vicoustic since I have a local retailer who can source me.
With respect to the 40 hz spike, I can't see anything that might work that low from their range....
So from what I understand absorption should be kept at minimum as it would intervene - mess up other frequencies which seem okay? is this correct?
Depends if you prefer a studio/headphones-like sound or more airy, spacious sound. Something like 0.4s I mentioned before could be a good compromise between the two and at high freqs you are close to that. Probably due to your curtains, rug and sofa.Hmm okay I will send my graphs to Vicoustic to make an offer.
Shouldn't the RT60 values be lower?
I tried with Dirac and the boomy bass is largely gone however it sounds thinner compared to before. Also I read that is not good to eq more than +/- 2-3db.
Also I need to find a way to only eq up to 300mh and not all the way or learn how to eq with REW and import those in Audirvana.
You can modify the Dirac target curve to your liking, try the Harman house curve for example.
It's okay to attenuate more than that but yeah I wouldn't add more than +3dB, actually I don't try to correct dips/nulls at all with EQ.
Just follow the steps in the video in post #10 and you should be able to create EQ filters with REW in no time!
So what are my options then? Eq that spike 3-4db i think would not be enough..
Would 1 make any difference or it has to be more than 1?your options are getting two subwoofers (or four preferably), they would complement each other so the dips and peaks would not be so huge.
I am waiting for a proposal tomorrow from vicousticone would definitely make a difference as the distortion would go down and you can place it independently from the speakers.
However to get that region really smooth without Home cinema level bass traps you need two or more.
First I would put some bass traps on the wall behind the listening position to smooth the 100Hz to 300Hz region. then I would get a subwoofer.
I will let you know what they suggest.. i assume a lot..
I can put some on the back wall and was looking for the small kef sub however is rather expensive..
Here are the graphs..
Green line taken with the speakers pulled back
View attachment 126168View attachment 126169View attachment 126170
Thats good to hear!!Green looks good above 100Hz! how far is the listening position from side and back walls again?
60cm now
and 1.40m from the side walls
