Digital volume control vs analog volume control
Wouldn't you prefer a single knob that magically adjusted all the different stages optimally for the desired level?
Once set, I only use one knob.
Seriously, the goal is the lowest residual noise at the end of the chain, and at the same time, allowing the level I need. In reality, it hardly varies- much. Preamp gain and power amp attenuation are the balancing act to get the lowest noise and maximum DR.
My power amps are in the 120dB+ S/N, so the limiting factor is usually the gain stage in front. And I like preamps, so 90dB+ S/N is the bottleneck with most of them in real terms.
At this time of the year, it doesn't matter. The airconditioning to keep me cool shaves off 40-50dB at least, so it's all academic. :)
I think we should make the distinction between volume control done at the software level (multiplying each PCM sample by a value between 0 and 1.0f), fully analog volume control done by a good old potentiometer, a digitally controlled volume input fed to the DAC chip and a digitally controlled analogue volume circuit (or chip).
I am going to investigate further but I recently noticed that my system seems to sound better (I know it could be placebo) when the volume control on Windows and on the playback software are at 100% and both the preamp and the amp are in the low tier volume.
Several effects could be at play here.
I don't know how Windows handle volume control internally, but I won't be surprised if it was all software, meaning very small loss until the signal is converted to PCM before being assembled as packets being sent over USB.
As far as I know, the data has to be converted to something like 16bit/44Khz up to 24Bits/192Khz or something. My source is Flac 16Bits/44Khz and I don't use any advanced drivers.
If the packets are sent as 16bits/44 it means that at 50% volume it is effectively sent as 15bits. No big deal, except when you play at very low volume like 4-5%. at this level the range loss might be noticeable, not sure.
Other effect is that amplifiers tend to have lower distortion at low volume.
If anyone investigated this, I'd be happy to read your findings.
I have both. Digital has rounding errors. Analog has issues with resistance strip/wiper. Honestly neither would make a significant difference.
My main rig is using digital volume control.
As far as I know in DAC, digital or analogue volume control doesn't make a difference in data being fed.. The volume will not touch the full blown data spending into DAC. As far as I know digital control is controlling the power rail of the DAC ship. Analogue is additional opsamp or discreet circuit to control volume after the DAC output. You will lose resolution in bits when you control in computing environment like using gain control in EQ for example.
This is the thread for you. It will keep you busy! https://www.audiosciencereview.com/...nding-the-windows-audio-quality-debate.19438/
On the other hand, digital attenuation usually reduces the (relative) distortion. If your goal is to maximise THD+N of the whole system, a combination of digital and analogue attenuation is likely to give the best result.
I figure, at least in terms of my digital source, I'm doing pretty well with a Benchmark DAC2 fed into a Benchmark LA4 pre-amp for attenuation.
Variable analogue output coupled to a properly dithered digital attenuator, just be aware when you attenuate digitally you turn down the signal not the noise whereas analogue attenuates both.
That’s a very loose statement, Keith.
If the noise is in the program, D and A both attenuate it.
If the noise is in the power amp, D and A both don’t attenuate it.
If the noise is in the preamp’s analogue circuitry, D doesn’t attenuate it, and A only attenuates noise in that part of the circuit which is upstream of the volume control, and does not attenuate noise in the analog circuitry downstream of the volume control. Since it would be poor design to put the analog volume control right at the output terminals, one would expect some analog circuitry downstream of the volume control, which the volume control will not attenuate.
Plus, analogue IC type volume controls introduce their own noise and distortion.
cheers
Not this again.
I can only speak from experience. I have two SMSL dacs with digital volume control and have tried bypassing my preamp but the results were not so good. The sound did not feel solid, impactful, and the bass wasn't as present when using the digital volume control at lower levels (about 60% or less). The sound is best with the dac at 100% volume, and then adjusting the volume with the amp or pre-amp.
I believe that You are sincere with Your statement, but on this forum the dominant ethos is that when somebody makes a an assertion that A sounds better than B, he should be able to back it up with at least one of the following things:
1. Competently performed measurements that show a meaningful improvement.
2. Competently performed controlled blind listening tests, that show statistically valid results concurring with Your statement.
3. Valid theoretical reasoning in line with our current understanding of related physics and audio engineering technology.
Did you at least match levels doing this comparison? And matching by ear does not count as it is not good enough.
digital volume dials are rubbish ! they have lots of issues in actual field
my Dolby Stereo CP200 fader is faster than most home theatres instant quick turn in less than 1.5s from fader 7 85dB down to 0
digital home theatres owners still be dialing down , and i seen snails do it a lot faster
my stomaudio and trinnovs are snails compared to Dolby Stereo CP200
This is the first time I have ever seen volume controls compared for…speed! :cool:
An analog pot is virtually instant. What does that prove? Nothing.
Slow remote volume controls are frustrating. When it's quicker to get up, walk over and twist the knob.
Studio consoles use sliding faders, which can be even quicker than rotating knobs.
Instead of littering the forum with another post I tought I might ask here.
I´ve been suggested to buy a power amp (Hypex Ncore 252 or more powerful) and a bluesound Node (2024) to simplify my setup and future proof it. I´ve been asking ChatGpt a lot of questions about this, and it warns me about "digital volume damping". As I´ve interpretated that means that when I reduce the volume (spl) on the node the digital signal weakens which in turn reduces the sound quality? I like to listen at various spl´s from low 40-50 to around a 100 db (when in that mode).
Is this true?
