Dear friends, do you know if the coax digital output of m-dac is volume controlled? If not, can you suggest me a gear with remote control, 2 toslink input, 2 spdif coax inputs and 2 digital outputs (coax + coax or AES) with controlled volume? Thanks
digital outputs are variable?A miniDSP Flex Digital would give you almost everything that you need for $500:
An external SPDIF switch could be used to add inputs.
Yes.digital outputs are variable?
Depends on the switch.but external spdif switch is not remote controlled, right?
i've to connetc my oled tv out, my android video streamer out, my hd audio streamer out, my coax cd out to my Genelec 1032C active speakers with AES digital input...
yes but it is a controller for a GLM module... one more remote... for volume only... i need a basket for the remote controllers... ;-)
remote + module is about 500 bucks here... anyway is a good solution...
The Ultra has just one SPDIF input.WIIM ultra. Does it all.
You are right.The Ultra has just one SPDIF input.
The Flex at least has two, though OP is looking for four.
www.advanceparis.com
What adaptor does one need for the AES hookup to my speaker.? Mine only has AES in. ?A miniDSP Flex Digital would give you almost everything that you need for $500:
