willi_vintage
- Joined
- Sep 5, 2024
- Messages
- 9
- Likes
- 27
Hi folks,
A few questions arose when attempting to design a waveguide for a tweeter. The primary goal is to adjust the delay between the woofer and tweeter. This results in a depth of approximately 15 mm. This should be used in such a way that the directivity is adjusted to the woofer and more strongly restricted vertically (e.g.: 120° horizontal, 90° vertical). The tweeter is a classic 25 mm dome and coupling should take place at 1500 Hz. A waveguide was designed using this data. What doesn't fit: the depth should be at least 30 mm. My primary design is limited to 15 mm, which is actually too little. The whole thing was simulated:
cross-section in the simulation (vert). For simplicity, the chassis is open at the rear:
and SPL @ 1600 Hz:
2860 Hz:
13550 Hz:
so far...but I don't see any differences in directivity (left guided, right unguided). The same applies to horizontal radiation behaviour. Wrong design, input or simulation? idk
and SPL @ 1600 Hz:
2860 Hz:
13550 Hz:
