Did Topping accidentally create a budget multi-channel DAC + pre-amp with crossover in DX1 II?
gtg465x
The fact that the new DX1 II is only $120, includes optical input AND output, RCA and balanced pre-amp output, and EQ provides some interesting options if you combine multiple of them together to essentially create as many output channels as you want, all controlled by the volume knob of the first, each channel with its own EQ and crossover filter. Having an optical out is one thing, but the options Topping provided with it are really what allow what I'm thinking:
1) It outputs to both optical and the RCA / balanced pre-amp outputs simultaneously
2) You can apply per channel EQ to the RCA / balanced pre-amp outputs, but disable EQ from being applied to the optical out
3) You can configure the device to control optical volume or not, so I think the first device in a chain of DX1 IIs connected to each other via optical can be the sole volume controller, with the others just passing through the optical signal unchanged down the chain.
Example 2.2 setup:
DX1 II #1 (volume controller for both devices):
- USB or optical in from your source
- Optical out configured to a) control volume and b) not have EQ applied
- RCA or 4.4 balanced left channel to speaker 1: L EQ with high pass filter and optional room correction EQ for speaker 1
- RCA or 4.4 balanced right channel to speaker 2: R EQ with high pass filter and optional room correction EQ for speaker 2
DX1 II #2:
- Optical in from DX1 II #1
- Volume at 0 db to not attenuate digital signal that was already attenuated by DX1 II #1 any further
- RCA or 4.4 balanced left channel to sub 1: L EQ with low pass filter and optional room correction EQ for sub 1
- RCA or 4.4 balanced right channel to sub 2: R EQ with low pass filter and optional room correction EQ for sub 2
In theory, you could keep chaining them for more channels with their own EQ. One possible downside is each additional DX1 II in the chain would presumably be ~1-3 milliseconds behind the previous with no way to adjust, but since this is a DAC advertised to gamers, I'm assuming the processing is very fast and very minimal, probably closer to 1 ms, which I don't think would be noticeable or much different than having a slightly longer cable going to the subs.
What do you guys think? Any obvious gotcha's I'm missing? While something like a miniDSP Flex would still provide more options, like delay and actual room correction software, it's 2-3 times the cost of dual DX1 IIs and is still missing headphone output, and if all you're really looking for is digital crossover config and basic per-channel EQ for 4 channels, this could make sense I think.
Plausible. Buy one for me, and I'll try it :)
You want to introduce 1 ms delay?
I don’t know what the delay through a DX1 II is. Could be less. I doubt it would be noticeable. If your subwoofer is 1 meter further from your ears than the mains, that alone introduces a 3 ms delay, and most people run setups like that without doing any sort of time alignment correction.
I just read the Topping DX1 II manual and skimmed the Topping Tune app manual and I couldn’t find a definitive answer on this, I would say no if independent delay can’t be applied to each channel. For example, for a multiple subwoofers and main speaker setup, how would I time align the subwoofers for max spl and then delay the subwoofer sum and speakers without delay functionality on the Topping.
I just read the Topping DX1 II manual and skimmed the Topping Tune app manual and I couldn’t find a definitive answer in this, I would say no if independent delay can’t applied to each channel. For example, for a multiple subwoofers and main speaker setup, how would I time align the subwoofers for max spl and then delay the subwoofer sum and speakers without delay functionality on the Topping.
You wouldn’t with this solution. You’d have to go for something quite a bit more expensive I think, like a MiniDSP Flex.
Yes, I was answering your original question. I wouldn’t personally bother doing this and I propose just get a Minidsp Flex. I personally would use a Minidsp 2x4 HD for a 2.2 setup.
Problem with 2x4 is the lower quality converters and the fact that you still need a separate DAC / preamp to control volume with a physical knob. And neither MiniDSP includes a headphone amp or outputs, so even after spending significantly more for them, you’ll still need to buy something like a DX1 II for a desk setup where you want to use headphones and have a volume knob.
The Minidsp 2x4 hd version 2 was measured here: https://www.audiosciencereview.com/...mple-measurement-and-teardown-pictures.50900/
102 Sinad which is more than good enough for me.
Anyone try this yet?
If delays are an issue, a TOSlink distribution box could mirror simultaneously.
Can this PEQ do HPF / LPF / Bandpass ?
I understand not true multichannel crossover no phase / delay tweaking, but magnitude only, one channel at a time?
:) its a future like apple ...
no i think its more expensive to block or control all the channel , moreover the control can change % of noise , more noise , little spec , etc etc ...
Example 2.2 setup:
DX1 II #2:
I thought something similar when I saw this Topping DX 1 II device for creating a digital crossover. But I thought about a different setup.
optical source -> optical splitter (optical splitter cable/adapter/device multi options available some are powered, some unpowered just splitting the optical signal but read the reviews not all function well) -> each optical output cable to one DX 1 II (so that's 2x or 3x DX 1 II (depending op splitter device) -> amplifier -> speaker (tweeter/woofer/subwoofer)
To control the volume of all DX 1 II simultaneously I thought about an IR extender cable and the 2x (or 3x) DX 1 II in a closed evironment to shield them from the original IR remote and the IR emitter of the IR extender in front of the 3 devices to control the colume all 3 at once!
Or a dedicated IR repeater system with one IR emitter to each DX 1 II (just some tape to attach the emitter to the device will do), here again the DX 1 II devices should then be shielded from the original IR from the remote. With this option instead of shielding some black/grey tape might also be able to block the IR signal from the original remote to reach the DX 1 II and the the IR emitter under the black/grey tape in front of the IR receive of each DX 1 II.
Each DX 1 II then can have crossover, gain and PEQ for each driver (tweeter/woofer/subwoofer)
I'm not 100% sure if this works?
