I musta missed some parts of your reply:
Why do you exactly need all of this costly 10GB network switches and Cat8 cables, for your 60k FLAC/WAV collection?
Wouldn't a local NAS and using a local DHCP for a local "
static IP" suffice and result in
*neater/*cleaner solution?
*neater/*cleaner, only because I will not debate claims of better sound.]
I had an internal debate with myself about whether I should end my post with "/s" but I didn't.
I had assumed that statements like "
Of course I need the headroom of this setup, which is capable of 5000 MBytes/second, to avoid contention/packet retries when playing back my 200 KiloByte/second FLAC tracks. You gotta have head room, just in case!!!!." would indicate where I stood on the computer audio bullshit/snake oil divide (i.e. pointing out why would anyone need such a high level of ethernet bandwidth when even 100mbit (10 MBytes/sec) ethernet has ample headroom for music streams.
Sarcasm is a national sport in my country and I sometimes err on the assumption that it is obvious to others.
Reassuringly, I have none of the things I listed aside from 60k of FLAC files (which I won't be converting to WAV for that extra level of fidelity)
My digital file delivery actually involves:
- A $200 used PC with a 4TB SSD drive ($200) running Linux (outside of my listening room in my server closet...down to 10 servers since retiring from Unix/Linux software development)
- A $200 fanless/diskless Intel PC (inside my listening room on my rack) running a ram booted Linux that mounts the flac files over NFS
- The fanless PC uses a $150 LPS and connects via USB into my DAC
- I have structured wiring in my house consisting of 48 runs of cat 6 that connects into a central patch panel
- The music server and the client are obviously connected via ethernet and I use an inline $50 ethernet isolater from a real world engineering company between them
- All external ethernet cabling (i.e. not inwall) is bog standard cat 6 (ie. what professionals such as myself use in data centers)
Total outlay is $800 (excluding the structured wiring)
I needed the structured wiring for my professional work where I had, at peak, around 20 different Unix and Linux servers (supporting various releases of HPUX, Solaris, AIX and the main Linux enterprise vendors Suse, Redhat and Ubuntu). Plus on top of that associated development workstations and backup servers that supported the workload.
Peter
