The voltage amp is class-A, the current is supplied by 4 (iirc) class D devices transformer coupled to the output and running at different phase to each other to further smooth the output current.
ADH stands for analogue digital hybrid. The digital bit is control of everything to do with preamp, phono stage and analogue inputs which are digitised immediately.
SAM is a DSP correction for speakers in the bass only, in order to run it you have to specify which speaker you are using in the configurator which then adds the appropriate correction for that speaker's bass into the configuration file.
As I have already written SAM was a later update, it is based on what they found developing the Phantom active range. The original ADH neither needs nor has SAM.
No zigs, no zags wtf that means!
As mentioned I was enthusiastic about the original product, to the point of strongly considering a purchase.
On to your comments above --
the voltage amp is class A
the current amp is class D
sure sounds like a current-dumper topology
SAM. I am aware this was a later development after the company culture degenerated from engineering-oriented to marketing-hype machine.
SAM is correction. How is it that no other firm has noticed the need for "correction" of this type? Applying scientific method -- if a speaker were measured with a known blameless amplifier (Benchmark, Eigentakt, Ncore 1200, ATI Signature for example), and then measured with a Devialet with SAM not enabled, what would you see?
BTW does it strike you as odd that none of the many speaker manufacturers, whose products have been "SAMed" have noticed these irregularities?
If you do not comprehend zig-zag then how can you refute it?
