Development of DIY Pi5 multi-channel soundcard
Hey everyone, I just wanted to let you know that this soundcard is live on crowdsupply.com - click the link to check it out and subscribe to project updates. I've been running the latest version myself for a few months as a digital 3-way crossover and it is working great.
If I want to use two processing the same input signal, is there a need / a way to sync the clocks?
You can feed both I2S clock signals from the first to the second board, and configure the I2S interface on the second RPi5 to be slave (i.e. the RPi inputs will switch to inputs). Still the moment of playback/capture start on each RPi will vary, introducing a fixed skew between the RPis, varying with every start.
FYI - the crowdsupply campaign has now launched and you can order the soundcard.
Looks great!
The shipping date says January?
What is it in reality? Is it certain, guaranteed or a roll of the dice like crowdfunding?
I have 8 units here because all of the development and prototyping is finished and I have the final design. When the campaign ends, I will manufacture any additional units immediately, but that takes a few weeks, and then I need to program the EEPROMs and do QA, before sending them to crowdsupply in the US. They will distribute them to backers. It’s conceivable it could be sooner but January is probably realistic.
So it’s certain that you’ll get the finished product (assuming some key component doesn’t suddenly become unavailable or there is a trade war), and it’s fairly likely to be January (or before).
> Orders placed now ship Jan 14, 2026
Aha, so maybe change that to 2027?
If a key component suddenly become unavailable or there is a trade war
will refunds be issued?
While Crowdsupply don't provide any guarantees, they give me the ability to refund people. If component costs increased by a huge amount then I would fulfil as many people as I can out of existing stock, refund everyone else and offer it at a higher price.
Nice work!!
Now that this is done, would you consider developing an 8 channel DAC board, perhaps with SPDIF input, with higher spec DACs? There is surprising dearth of high end multichannel DAC Pi5 hats in the market. Many hobbyists would love to use a Pi 5 with a high spec multi channel DAC to do digital crossovers for multiway speakers and run DRC.
Nice work!!
I am thinking of creating a variant to this board that has one or two digital inputs in addition.
The challenge with some of the higher end DACs that I looked at is that Linux drivers aren’t yet available, so there is a fair bit of work required to use them. I might look at the options again.
Thank you for the reply.
I’m not familiar with the raspberry pi system, so It’s not clear to me why a Linux driver would be needed for the DACs. When time permits, would you mind posting a brief explanation?
Over on diyaudio.com there have been a number of stand alone stereo DAC projects using ESS and AKM parts. Could the hardware not be designed in such a way that the output DACs, say 4 stereo DACs, are isolated from the operating system?
Sticking to multichannel I/O really does thin out the competition, especially if higher SQ specs.
For me 8-channel is just a starting point but allowing expansion via multiple boards with solid clock sync'ing ideally BMC Word Clock, would be great.
S/PDIF Coax RCA native, easily "converted" to either TOSlink or AES3
ADAT ports to allow for dumb expansion via stock AD/DA conversion units, or the various AoIP network protocols.
and yes the OS is isolated, no awareness how those channels are implemented
And DSPi I think is ripe to enable a lot of this if not for convolution heavy lifting, but even just for facilitating the format conversion, let the host PI5 be the "primary interface", toggle to OTG gadget mode for flexibility.
USB in and out just requires UAC2 compatibility, no bespoke drivers.
