• WANTED: Happy members who like to discuss audio and other topics related to our interest. Desire to learn and share knowledge of science required as is 20 years of participation in forums (not all true). Come here to have fun, be ready to be teased and not take online life too seriously. We now measure and review equipment for free! Click here for details.
Designing a 3D Printable Case for the Khadas Tone Board
#42
~80 cents for the ABS, plus about 20 cents for the electricity. I printed the case solid which is probably a bit overkill.
Printed a second one in PLA just in case I miscalculated the shrink rate of this ABS. The PLA print will be a fairer evaluation of how well the model fits.
How much longer until your board arrives? The cases are looking great!
California
#44
My board is here, I am printing the model right now.
California
#45
For the front panel. The USB port needs to be a little bit wider (like 0.5mm), otherwise almost perfect fit. Printing the case body now (2.5 hours)
#46
Got it, thanks! Will modify and update the stl in a little bit then. Lemme know how things fit when the body is done!
California
#47
Unfortunately the case doesn't fit. The model does not taken into account of the space that those surface mount component under the board takes. the holes on the front panel needs to move up a bit to fit. (about 2mm)
California
#48
Actually probably 1.5mm is fine, 2mm seems too much. I am trying to make up a front panel that is fixed. (not a very good 3d modeler)
#49
Cool, and thanks! Yeah, I couldn't find any information on the thickness of components underneath or if there was any at all so I was kind of worried about that. Edited and uploaded a new backplate stl file with all holes shifted up 2mm and the usb c slot widened 0.5mm. Lemme know how things work
Edit: Lol, just saw that last message, I'll just upload a version with the holes shifted 2mm and one shifted 1.5mm one so you can try both
California
#50
Great, printing one right now. Thanks for telling me that so I don't struggle with my sketchup...
California
#52
Revised panel is a Good fit.
Final adjustment would be to widen the usb-c port further 0.5mm on the right side in this picture.
I personally also think the screw holes are not very useful since 90% of the weight is the RCA port, which is handled by the front panel.
#53
So the 2mm revision was correct? got it on the usb c port revision, modified and updated. Yeah, was debating the screw holes too, didn't think they'd really be necessary, but left them in in case someone wanted to screw things in to be extra sure things wouldn't go anywhere.
California
#54
Yes the 2mm revision was correct, thanks for your design
#56
would you please upload the final design file with "widen the usb-c port further 0.5mm on the right side "?
It's already uploaded? or at least, I know I uploaded those changes about an hour and a half ago. Just waiting for my board to come in tuesday or another few members who have the board in hand and a 3d printer handy can verify things fit before I take off the work in progress tag
#57
My board will be coming sometime in the next week or so. Got some new PLA in today so I'll print the new designs out and report back how it fits when I get my board.
azif
#58
Looking to print this on 3d hubs
What material / layer height / infill would you pros recommend?
California
#59
Tolerance on this is pretty good and there isn't any real load on it. PLA and 10% infill is sufficient.
#60
My tone board arrived today. I ordered one of the DIY cases for Khadas board but they didn't send it. Looks like the whole enclosure can be 3D printed? I don't have a 3D printer. Would someone be willing to sell me a case?
