2 questions please:
1st off - I seem to have an issue with at least 2 terminals on my Denon X7200W - seems to be the Surround Back Right and Front Wide Left terminals - ie next to each other
over time the outputs to these speakers get lower and lower and the low frequencies reduce, if I put some slight pressure up on the terminals the sound comes back and then is good for a few weeks. I had assumed when I thought it was one terminal that it must be the soldered connection to the terminal from the board, but now I've realised it is affecting 2 outputs I'm wondering if it is some bend or loose connection on the board - does anyone know how they are connected up please ? I've looked at photos online but can't see below the HDMI board so can't see how the speaker outputs are connected
I did think maybe I could "prop" up these speaker terminals so some pressure always applied vertically rather than the weight of the speaker cables- might be a not-ideal fix, else I could go in and attempt to fix myself (out of warranty) but my electronic skills and soldering skills aren't completely good enough to not ensure I wouldn't damage the whole av receiver. Propping up and if they get worse over time I could always buy a multi-channel power amp.
2nd question I have please - is regarding Dolby vs Height speaker settings. I have KEF Q350s as rear heights and KEF Q50as as Front Upfirers, I had until this evening set the Front Upfirers also to Heights until I read a thread earlier that said Upfirers should be set to Dolby Speakers (I hadn't even realised there was a "Dolby" option tbh)
I noticed when I set the Q50as to Front Dolby that I can't EQ above 1khz (I manually EQ). What I don't understand and was hoping for some info please is whether the processing is applied differently when set to Front Height vs Front Dolby ? I thought if any HRTF was applied to Upfirers it was set in the speaker themselves within the crossover not on the amp ? If no difference in processing why would one setting not allow EQ above 1khz ? Or does it apply some form of LPF if they are set to Front Dolby ?
It had sounded very good set to Height tbh and I was able to EQ above 1khz, I've yet to try fully set to Dolby
many thanks for any info
