PHD
- Joined
- Mar 15, 2023
- Messages
- 298
- Likes
- 451
Hi
After only 2 weeks of usage, now, when I turn the X4800H on, the main PSU relay makes a loose spring or flutter noise randomly.
In this video the spring sound only happens at the 2nd turn-on attempt:
www.dropbox.com
Here it happens on the first turn-on attempt:
www.dropbox.com
Looks like some other users have reported the same issue:
My dealer is checking the issue with Denon and should report back. Is anyone else having this issue here? Does it sound like a faulty to dying relay or is it normal? Should I insist on getting it replaced/serviced?
Thanks
Dropbox
Dropbox
Thanks
