Denon X4800H audio will randomly cut out for a couple seconds when streaming
starfly
I’ve noticed lately that my X4800H will maybe after like an hour of listening start to randomly cut audio for a couple seconds at a time. This happens when streaming through Spotify Connect. Extremely annoying and not sure where to start troubleshooting this issue.
Front speakers are powered through an external amp. When I see it happen it looks like the little icons for the front speakers in the front display turn off and then back on again.
Has anyone run into an issue like this before?
It's most likely your LAN, rather than a hard fault if any part of the LAN is using WiFi (or if you use Bluetooth). Distance can cause packet loss, as can interference from other nearby wifi routers.
Some LAN connected-devices like streamers do however have poor quality wifi/ethernet modules and I know of a few modules that got replaced under warranty on certain kit.
If your network uses entirely ethernet cabling, and you still have a problem, I have heard that some streaming apps have had faults (including Spotify Connect), so make sure you have the latest version.
If the music data travels through a phone at any point (as a relay), as opposed to using the phone as a controller, then the phone may be the problem, if power saving modes can kick in.
Start with local media. If it's not happening there, it's an internet problem. Buffer underrun is the term.
It’s mostly odd they it only appears to happen after listening constantly for 1-2 hrs, so also not easy to reproduce. My Denon is hardwired via Ethernet. It’s running through an unmanaged switch that also has an Apple TV, PS5 and my TV connected to it. I think it’s only connecting at 100mbps instead of 1Gbps based on the yellow light on the switch port, could likely be the Denon is limited to just 100mbps?
That entire switch is then connected to a managed switch that links up everything else in my network (including WiFi APs - running UniFi gear).
Have you tried a soft reset? (i.e. simply unplug the avr from power for a bit, like 10-15 seconds). If not that how about a full microprocessor reset?
Happens all the damn time with my 3600. So frustrating.
Mine streams via wifi and I'm fairly confident the problem is nearby network traffic in NYC apartments. So I bought a wifi node and connected the Denon to the node by ethernet. Much better but still not perfect.
So sometimes I just unplug the Denon. That seems to 'clear' it pretty effectively.
If you figure out a reliable remedy please let us know!
And of course today I’ve already been listening for 2-3hrs straight and so far no issues. Haven’t changed anything about the config, but did setup a new phone today. Though with Spotify connect the phone just acts as a controller.
